It is currently Fri Aug 22, 2025 5:22 pm
PostPosted: Sat Feb 15, 2014 10:45 pm
I've got a 1965 Melody Maker on the bench recovering from a tragic moving mishap. The original pore filler is bright red. I've been having trouble duplicating this color using pore fillers and Mixol pigments and Trans Tint dyes. If I start with a light color it dries pink, starting with a dark filler dries brown. Does anyone have a recipe for bright red goo?
PostPosted: Sun Feb 16, 2014 8:46 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I find Solar-Lux Med Red Mahogany to be a good match for older Gibson stuff. You need to load the paste pretty heavy with it or it will dry pink. Gibson's process was a bit different then most from what I can tell, they applied the filer to bare wood and it was an all in one filler/stain combo. I usually wind up putting down a tint coat of lacquer with the same color added to it to get it to blend in nicely before hitting it with the clear.
Brian
PostPosted: Sun Feb 16, 2014 6:24 pm
Thanks Brian,
I quit pussy footin' around and added a lot more pigment. Twice. Finally got to where I was going.
PostPosted: Mon Mar 03, 2014 7:02 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Gibson uses dark walnut pore filler for their heritage cherry finish on SG's and juniors. They then seal it. They then used a cherry toner for a few coats then multiple lacquer clear coats over top of that...Mike
Another day, another dollar.
