It is currently Mon Aug 25, 2025 3:11 am
PostPosted: Mon Mar 03, 2014 5:48 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
Anyone else here have any experience with the vacuum kits from Veneer Supplies or similar?
http://www.veneersupplies.com/products/ ... s-Kit.html
I have the V2 model from them and before I assemble it I've been keeping my eye out for an alternative to the suggested PVC vacuum tank system they suggest.
I just came across this cheap compressor tank from home depot and it looks ideal and far superior to a homemade PVC tank.
http://www.homedepot.ca/product/5-gallon-inflation-tank/814247
I'm wondering if any of the vacuum users here have any thoughts on using this tank for vacuum instead of compression.
Hopefully this could be a useful and inexpensive tank for vacuum use.
Also just want to say that I'm new to this forum and have learned a ton here reading through the old threads. Thanks to you all. :)
PostPosted: Tue Mar 04, 2014 6:26 am
Last Name: Ball
I have a rig exactly like that that I use for vacuum bagging--the Veneer Supplies kit and a 5 gallon air tank. I've used it for years with no problems at all.
These users thanked the author ballbanjos for the post: Durero (Tue Mar 04, 2014 12:31 pm)
PostPosted: Tue Mar 04, 2014 12:31 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
Thanks for sharing your experience Dave.
I'm going to order one. :)
PostPosted: Tue Mar 04, 2014 4:41 pm
My position goes against the common recommendations but I've spoken with a few other vacuum users that agree and it's basically that for vacuum clamping, a reservoir hinders performance rather than improving it. For vacuum bagging, it seems to be an improvement over no reservoir, at least in terms of the pump cycling.
I've found that the lower the volume I have under my parts for clamping, the quicker I'm able to get higher vacuums and pull a higher vacuum over all. It is important to have channels leading to all parts of your fixture
That said, I have a little 1.1cfm pump that I use for bagging and although it runs all the time, it's super quiet so it doesn't bug me.
These users thanked the author Andy Birko for the post: Durero (Tue Apr 08, 2014 5:30 pm)
PostPosted: Tue Mar 04, 2014 5:48 pm
Last Name: Ball
I agree--I use a little continuous running piston pump for clamping--it's quiet and quick. But the reservoir is great for the initial "suck down" with a vacuum bag, so I use the venturi with the tank for lamination work.
These users thanked the author ballbanjos for the post: Durero (Tue Apr 08, 2014 5:30 pm)
PostPosted: Fri Feb 06, 2015 9:46 pm
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
Surge tanks act as a capacitor for vacuum. If you don't need a temporary high cFM rate, you don't need a surge tank. If you do, PVC works great.
PostPosted: Sat Feb 07, 2015 3:48 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I found an old air compressor tank at the dumps buy back shop for a couple of dollars. Does the trick just fine.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sun Apr 05, 2015 10:15 am
Last Name: Garrish
Agreed with everything Andy and Dave have said.
Just as a note: when vacuum bagging, put the tank on a ball valve T-ed off of the main vacuum line to the pump so you can close it off from the system after the initial suck-down. If you leave the tank in the system, it takes much longer to get up to full vacuum in the bag.
Bob Garrish
These users thanked the author Bob Garrish for the post: Durero (Mon Jan 04, 2016 11:37 pm)
