It is currently Wed Jul 23, 2025 6:37 pm
PostPosted: Sat Feb 01, 2014 12:57 pm
First name: Mark
Last Name: Sweeney
City: South Ohio
State: Nova Scotia
Zip/Postal Code: B0W3E0
My latest build is buzzing like crazy when plugged in, so I assume I have a grounding issue. all cavities are shielded properly with copper foil tape, I've triple checked my wiring and all looks good. the only thing I can figure, is that the bridge is not properly grounded. I have a brass baseplate for my bridge that is painted black, I scraped some paint off around where the ground wire comes in, but wasn't able to solder the wire to it, and if it did stick, it wasnt lining up properly with the hole, and would break off very easily. so after a quick google search, I read that people were just running the wire through the cavity, and leaving some bare lead under the bridge, but no technically attaching it. I tried this, but it hums very bad, and I also seem to have volume issues.
Is there a better way?
What do you guys do?
PostPosted: Sat Feb 01, 2014 1:13 pm
First name: Stuart
Last Name: Gort
I drill and tap a hole in the base so my connections are always a sort of screw terminal type.
You could do this easily by getting the right size hole drilled and then hand tapping with a little bottoming tap. I can help you pick the drill and tap but you have to start with the right little screw and work back from there. Once you have the screw you want to use I can call out the right drill size for that tap.
StuMusic
PostPosted: Sat Feb 01, 2014 1:18 pm
City: chicagoland
State: illinois
if all else fails, you can disconnect most or all of the wires, leave the control cavity plate off, get some alligator clip test leads, and fool around with different wiring permutations (with the guitar plugged in to the amp) till you get an acceptable circuit...
if the output signal is weak, a good portion of it is probably being bled to ground.. i'd look at the volume and tone pot(s) connections
PostPosted: Sat Feb 01, 2014 7:49 pm
First name: Mark
Last Name: Sweeney
City: South Ohio
State: Nova Scotia
thanks guys, Got it fixed, I was confused about the wiring of the jack apparently..... a little embarrassed....
PostPosted: Mon Feb 03, 2014 1:13 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I was going to say check the jack, swapping the hot & ground will produce your symptoms. DAMHIKT.
