It is currently Fri Jul 18, 2025 11:52 pm
PostPosted: Mon Aug 26, 2013 2:43 pm
First name: Eric
Last Name: Gleason
City: ALBANY
State: New York
Zip/Postal Code: 12208
I've been looking for a source for 4mm truss rod nuts for import guitars. I've had quite a few come through the shop that are stripped and in need of replacement, and I've never had a good way of dealing with it.
Anyone have a source? The closest I've found is the 9/64" truss rod nuts that LMII sells. StewMac doesn't have anything, nor do my usual parts suppliers.
PostPosted: Sat Nov 16, 2013 9:42 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Your local friendly hardware stores often have whole shelves of fasteners and 'stuff' of all kinds that can be purchased singly. Depending on how deeply the store is stocked, they might have metric nuts and bolts and washers in the inventory. The one near me stocks metric fasteners. Each merchant can stock what he wants and the salesman keeps the stock filled, so each store can be unique. But I've had many happy hours cruising the partitioned drawers looking for something I couldn't live without.
Peter Havriluk
PostPosted: Sun Nov 17, 2013 8:39 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Not going to find those at your local hardware store. Don't know of any one selling much other than the standard Gibson or fender replacements. You could always make your own. They would most likely need to be adjusted by a screwdriver or standard socket instead of an Allen wrench.
Brian
PostPosted: Sun Nov 17, 2013 9:41 am
First name: Eric
Last Name: Gleason
City: ALBANY
State: New York
I think you've misunderstood what I need. Looks like the one below and requires a 4mm allen wrench to adjust. It's narrower than the standard ones you can get that adjust with a 5mm or 9/64" wrench, and is very common on cheap import guitars. Hardware stores don't have anything like it.
PostPosted: Sun Nov 17, 2013 11:49 am
Last Name: jennings
City: Lopez Island
Zip/Postal Code: 98261
You might give the folks at LMI a call and ask them. The one you picture looks much like the one they use in the ["USA made"] truss rods they sell, also 4mm.
MJ
PostPosted: Sun Nov 17, 2013 1:11 pm
First name: Eric
Last Name: Gleason
City: ALBANY
State: New York
That's a good idea!
PostPosted: Sun Nov 17, 2013 9:56 pm
First name: Eric
Last Name: Gleason
City: ALBANY
State: New York
Their nuts all use 9/64" wrenches, but the dimensions look right. I was focused on the 4mm spec and didn't even look at the important dimensions.
PostPosted: Thu Nov 21, 2013 10:47 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
I get 'em from Martin, although I haven't tried lately. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
