It is currently Fri Jul 25, 2025 6:40 pm
 Post subject: neck through belly
PostPosted: Sat Oct 19, 2013 11:19 am
First name: Wes
Last Name: Richards
City: Livonia
Zip/Postal Code: 48152
should i sand down a slight belly in the neck to compensate for fret deflection , the neck wood is African mahogany with a ebony fret board ,22 frets.
 Post subject: Re: neck through belly
PostPosted: Thu Oct 31, 2013 2:53 pm
If your neck is straight - and your fretboard flat when glued down - then when you fret it you should see a slight back bow to the neck as a result of the fret tangs being wider that the fret slot - I would leave this well alone as pretty normal - when you string, the tension will straight the neck and the rest is then managed with the trsus rod. Should be no need to 'sand' the fretboard in any place - just get them nice and straight before you glue up or fret.
PostPosted: Fri Nov 01, 2013 11:05 am
Depends on if you're using a double action truss rod or not. Some guys like to put a small hump in the neck nd flatten it out before radiusing to assure relief in the neck after fretting.
Old growth, shmold growth!
PostPosted: Fri Nov 01, 2013 6:01 pm
First name: D
Last Name: S
That's what I do when using a single-action rod.
I glue my fret board blank to the neck, level the board, create a slight hump, re-level the board, saw frets, taper, radius, polish, apply finish (if desired) and then install the frets. I've used stiff wood like Mesquite for necks and I want to ensure I can get relief.
It may be overkill but it works for me.
Dan
wah
Wah-wah-wah-wah
Wah
