It is currently Tue Jul 15, 2025 10:51 am
PostPosted: Sun Oct 06, 2013 11:25 am
First name: Britt
Last Name: Askew
this is a StewMac .010 file. I was surprised to see the file's condition when I opened the box. It was bent and twisted. I tried to straighten it a little and clamped it to a straightedge over night but is still looks terrible. Is this normal?
PostPosted: Sun Oct 06, 2013 11:30 am
Umm no, that's not right. Send 'em that pic and they'll send you a new one. You really can't 'fix' a bent file, it's too hard and will break.
PostPosted: Sun Oct 06, 2013 12:50 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
You probably should get a replacement, but something I would try first is heat it to 400 degrees in your oven for an hour, then while it's hot, clamp it tightly between two thick metal plates (or whatever you have, as long as it's straight and rigid). After it's cool, unclamp it and see if it changed. If it didn't change, get it hot again, and try to straighten it with gloved hands. I have to do this occasionally with knife blades so it can work. Wear eye protection in case it does break.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Sun Oct 06, 2013 2:05 pm
First name: Britt
Last Name: Askew
I am going to try and straighten it , oven is getting hot now. I will show the outcome later.
I just wanted to make sure this was not normal for these files.
PostPosted: Sun Oct 06, 2013 6:28 pm
Baking the file may take the temper out of it and make it wear prematurely. Send it back!
PostPosted: Sun Oct 06, 2013 6:49 pm
First name: duh
Last Name: Padma
No, me file didn't come bent like that...but me...me came pretty bent outa shape...no big deal...me still be gettin stuff done. laughing6-hehe
PostPosted: Sun Oct 06, 2013 8:35 pm
First name: Britt
Last Name: Askew
It took 2 tries , The 1st time I clamped it between 2 files and there was no change. 2nd time I used a couple brass rods and worked it from both sides and got it usable. The picture shows the file beside the cover it came in, big difference. I am not worried about the temper to much at 400.
PostPosted: Sun Oct 06, 2013 8:37 pm
First name: Britt
Last Name: Askew
duh laughing6-hehe
PostPosted: Mon Oct 14, 2013 12:35 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I cant understand how it bent like that in the first place. I would have to say it was defective from the get go and would have requested a replacement. Files don't bend like that they break!
Another day, another dollar.
PostPosted: Mon Oct 14, 2013 8:58 am
First name: Phillip
Last Name: Patton
City: Yoder
Some files are made of soft steel which is then case hardened. That type will bend, not break.
Regards,
Phillip Patton
PostPosted: Mon Oct 14, 2013 12:30 pm
First name: Britt
Last Name: Askew
I dont know how it got bent but the way the plastic cover stays bent when empty tells me it has been bent for a long time. I emailed Stewmac and told them about it and directed them to this thread for pictures. They refunded the money and promised to check their remaining inventory to make sure no others were bent so it wont happen again. I will order a new one next time I place an order.
