It is currently Sat Jul 05, 2025 10:06 pm
 Post subject: Router or Spindle?
PostPosted: Mon Aug 26, 2013 3:10 am
Which is better?
I've decided that if I'm going to spend $3000 or so on a milling machine to do just pearl cutting but it only goes to 11000 RPM then I might as well find a sturdy platform and fill it with nice components for about $6000. Twice the money, but 24X48 inches worth of work space gives it ten times the capability. I could all things guitar related, from manufacturing necks and bodies, cutting fancy/schmancy rosettes, to cutting my "S"'s and possibly making some hardware.
So if I want to machine bridges out of brass components as well, then I need to know what will do it.
Anybody doing stuff like that?
Old growth, shmold growth!
 Post subject: Re: Router or Spindle?
PostPosted: Mon Aug 26, 2013 8:40 am
It seems you've taken the red pill. I think there's quite a bit more research for you before you pull the trigger. Here's a thread I started when I was at a similar point: viewtopic.php?f=10106&t=30245&hilit=taking+the+plunge#p401309
PostPosted: Mon Aug 26, 2013 11:06 am
Thanx!
PostPosted: Tue Aug 27, 2013 5:40 pm
Last Name: Garrish
For your answer, though: spindle. They're so cheap now, on eBay or though AutomationTechnologies, that I can't see any good reason not to get one.
Bob Garrish
These users thanked the author Bob Garrish for the post: theguitarwhisperer (Tue Aug 27, 2013 6:42 pm)
PostPosted: Tue Aug 27, 2013 6:42 pm
They look like they can achieve higher RPM's in a smaller package, too.
PostPosted: Wed Aug 28, 2013 4:31 pm
Last Name: Garrish
The main difference between a router and a spindle is the motor type. Spindles use three phase brushless motors, which are much more efficient than the universal motors used in routers (ie: lighter, stronger, faster). Also MUCH quieter.
Bob Garrish
PostPosted: Sat Sep 21, 2013 8:54 pm
error, wrong thread.
Ken
