It is currently Sat Sep 20, 2025 11:08 pm
 Post subject: Walnut Bass Body
PostPosted: Thu Jul 18, 2013 1:42 pm
First name: Chad
Last Name: Thorne
City: Pittston
State: Maine
Zip/Postal Code: 04345
Hi, all, not really a luthier but have a "luthing" question. I have a bass with a walnut body I bought off Ebay. The bass sounds awesome but is it heavy. I also think it's a bit thicker than a typical Jazz Bass body.
My question: If I were to reduce the thickness of this body by, say, 1/4", maybe by running it through a planer, would that lighten it appreciably? Also, would doing that alter the tone of the instrument significantly? Thanks for your help!
 Post subject: Re: Walnut Bass Body
PostPosted: Thu Jul 18, 2013 2:04 pm
First name: Mark
Last Name: Sorrentino
It will not alter the tone but unless the body is extra extra thick, you might not lose as much weight as you think. Walnut is somewhat heavy. I just live with it. If it's a jazz bass body, thickness might not help you and chambering might be the only way. What kind of hardware/pickups do you have? Metal weighs a lot more than wood. How's the balance? Do you have neck dive? Pictures? Your pickups might be a good half a pound, or even more.
PostPosted: Thu Jul 18, 2013 2:30 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Weigh the body and measure the thickness. The amount you reduce the thickness, divided by the total thickness, times the total weight is a pretty good approximation of the weight reduction.
For example, 1/4" reduction, 2" thickness, 10 pounds --> (.25/2)x10 = 1.25 pounds less
edit: Chambering is the better option for weight reduction, but is a bit problematic on a completed body. You could resaw a 1/4" plate off the back, chamber the body with fostner bits or a router, and then glue the plate back on. I wouldn't recommend doing that unless you're pretty good with a bandsaw.
PostPosted: Fri Jul 19, 2013 4:23 am
First name: Mark
I agree with roger. I think it might be more work than youd really wanna do to make a heavy bass lighter. I'd either live with it, buy a new bass, or build one.
PostPosted: Fri Jul 19, 2013 10:38 am
First name: Stuart
Last Name: Gort
Just do the math. Express the 1/4" as a percentage of the total thickness and then remove that percentage from the total weight.
But I wouldn't do that unless I KNEW how deep the wiring channels and pickup cavities ran.
StuMusic
PostPosted: Sat Jul 20, 2013 1:35 am
1/4 inch isn't really much.
Old growth, shmold growth!
PostPosted: Sat Jul 20, 2013 11:31 am
First name: Mark
Walnut works great for a smaller body bass. Unfortunately the most popular bass shapes (jazz and p) are big enough to serve as a small coffee table. You could sell it, some guys drool over heavy basses.
PostPosted: Sat Jul 20, 2013 3:24 pm
First name: Chad
Last Name: Thorne
City: Pittston
State: Maine
Thanks, all. I just love the tone of this bass. I guess I'll keep it as is, pick up another body some place, and try it out. Worst case scenario, I go back to the walnut body.
PostPosted: Sat Jul 20, 2013 3:53 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Good bass tone comes heavy. Period.
Doug
PostPosted: Sun Jul 21, 2013 12:25 am
First name: Mark
See, that's what I mean. Now I'm reinspired. I've got a fretless five in my head that I intend for my own collection. I have a chunk of cocobolo that's thick and long enough for a one piece bass neck. I was thinking however, of using cocobolo for the neck with a katalox fretboard, which I also have cut and ready, and fill the fret slots with cocobolo veneer. I have a giant chunk of cherry I could use for the body, with some cutting and planing, and a sweet maple burl top.
PostPosted: Sun Jul 21, 2013 8:28 am
First name: James
Last Name: Tonguet
City: Duluth
State: Ga
Zip/Postal Code: 30096
I recently finished an all walnut guitar and I chambered it with good success. Total weight is only 6.5lbs
PostPosted: Sun Jul 21, 2013 9:38 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
My 4 string Warwick electric is 8lbs 4 oz. Solution: a wider strap with padding. But the tone and sustain is oh so good!
Doug
PostPosted: Mon Jul 22, 2013 4:04 pm
First name: Rodger
Last Name: Knox
City: Baltimore
There's huge chambers in this monster maple neckthru, and it still goes over 12 lb.
PostPosted: Mon Jul 22, 2013 5:47 pm
First name: D
Last Name: S
Dang Rodger!
Sweet!
I hope I can build like that when I grow up!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Jul 23, 2013 11:00 am
First name: Rodger
Last Name: Knox
City: Baltimore
Thanks, Dan. Is the Rock still there in Brushy Creek?
It came out pretty nice, but I'll never build another like it! As a neckthru, it was big, heavy, and hard to work on from the initial glueup to final finishing.
