It is currently Tue Jul 29, 2025 7:20 am
PostPosted: Thu Jun 20, 2013 8:13 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
What is the prevailing method for bridges and fretboard extensions????
idunno idunno idunno
MK5acoustics.com
PostPosted: Thu Jun 20, 2013 8:18 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I generally don't mask them. I find the tape gets in the way of level sanding and buffing. I rout the lacquer off down to the sealer and then scrape off the sealer.
Brian
PostPosted: Thu Jun 20, 2013 9:03 am
First name: Tony
Last Name: C
City: Brooklyn
I don't mask because I don't locate the bridge until after I have buffed the finish and made sure the neck fits perfectly after is has finish on it as well. Thus, I scrape it off. I am not a big fan of scraping it off, but I prefer to locate the bridge after all of the finishing has been done, so I don't have much of a choice now, do I?
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Jun 20, 2013 9:39 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I've tried both masking and scraping. Both have their own advantages, but both have
disadvantages as detailed above. I've just made the jigs for routing a small undercut
around the edges of the bridge, and routing off the finish leaving .001-.0015 gap under
the bridge for glueline. I'll be using them on two guitars later this week. I don't see any
disadvantages to this method, other than cost/time to make the jigs, and getting depth
control dialed in.
Gene
PostPosted: Thu Jun 20, 2013 9:54 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
"+1 tony, finish first, masking can be a pita.
PostPosted: Thu Jun 20, 2013 10:16 am
I mask. I'm surprised to hear that people don't like it, I find it pretty simple.
I use the Friskit film. I'll put layers on the body around the neck to simulate a film thickness when setting the neck prior to finishing to more accurately locate the bridge. The film is .03 or so so can also be used to gauge your final film thickness at the bridge area when level sanding.
Joe always asked me to mask off slightly smaller than the bridge when I sent guitars to him and I still do that. Once the guitar is buffed I lightly score around the bridge with an exacto and a sharp chisel pops the little bit of leftover finish right of, leaving a perfect opening for the bridge. That part is pretty simple too, just requires a few anal moments with the chisel.
I could never figure out how to make the ledge exact enough. I figured it was either going to show a small gap or not make a good glue joint at the edges. Not that it doesn't work, I just wasn't confident of the method.
Burton
Brookline, MA.
PostPosted: Thu Jun 20, 2013 11:04 am
I mask mine off like Burton, slightly smaller than the bridge. The Frisket film I use is .001 thick, so you can level the finish right over the masked area.
Chuck
PostPosted: Thu Jun 20, 2013 12:22 pm
Same as Burton for me too. I can't imagine placing a router near a finished guitar eek
If you make it slightly smaller it also gives you the advantage of tweaking the location. If you need to tweak it anymore then that imho you've made a worse error. Also by making it slightly smaller you can buff it out and the finish-to-tape line that it makes will simply be cut out.
PostPosted: Thu Jun 20, 2013 1:20 pm
Undersized Frisket film, 1 thou, matt, extra tack was recommended in a thread here on OLF.
I tried it on my last finish, and after a few coats the thickness just disappeared as I sanded/levelled/buffed, but the matt of the film could still be seen making removal a breeze.
I'm a convert. bliss
PostPosted: Thu Jun 20, 2013 2:59 pm
Last Name: Beaver
City: Lake Forest
I've been using masking tape under the bridge and the FB extension. The Frisket sounds very good. Thanks guys.
One question, where do you buy it? Art store? Hobby store?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jun 20, 2013 3:17 pm
I do the same as B Howard. Rout and scrape as well as sand with small blocks. Just did two. I'm another guy that does not like locating the bridge until the final neck position is known.
PostPosted: Thu Jun 20, 2013 5:22 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
+1 for Friskit film.
Fred
Fred Tellier
PostPosted: Thu Jun 20, 2013 8:09 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
I have been at work all day, interesting responses....another question , does anyone apply finish to the bridge?????
MK5acoustics.com
PostPosted: Thu Jun 20, 2013 8:14 pm
First name: Tony
Last Name: C
City: Brooklyn
Classical guys do. Sometimes.
PMoMC
PostPosted: Thu Jun 20, 2013 9:35 pm
Last Name: Beaver
City: Lake Forest
As Tony said, many classical builders finish the neck with the body after it has been attached, and some may do the same with the bridge. I don't. On SS I cheat tradition (meaning the Martin way) and put a little oil finish on the bridge to seal it.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jun 20, 2013 9:56 pm
Another one here using slightly undersized frisket. Routing seems so appealing but I just can't get the confidence to take a router to a finished instrument. Maybe one day.
PostPosted: Thu Jun 20, 2013 10:44 pm
First name: Randolph
Last Name: Morris
Friskit film source? :-)
PostPosted: Thu Jun 20, 2013 11:40 pm
A good art supply store.
PostPosted: Fri Jun 21, 2013 12:02 pm
I learned it at the Fox course in 2004. My rig is a StewMac Dremel base with a 1/8" spiral downcut bit. Cork on the bottom of the base. (Charles used felt) Mask off the top with low tack drafting tape and score the bridge outline as usual and score another line 1/32" inside. That's the line I rout to and clean up the edge with a chisel.
You can creep up on the depth pretty easily so you just skim the top wood. The cork or felt allows you to vary the pressure and depth a smidgen. Scrape and sand afterwards.
You have to really be careful to square off the corners of the wings so residual finish does not prevent contact and make sure ALL the sealer is off.
Still takes me 2 hrs from start to having the bridge undercut prepped and clamped up and I've done it over 50 times. Still gets my heart rate up a bit but no disasters so far.
I'd be interested in more detailed descriptions of other's router technique and also the Friskit technique.
PostPosted: Fri Jun 21, 2013 8:12 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I mask and find it very simple. I use two layers of wide blue painters mask. When I am done spraying, I remove the top mask, which allows me to easily level and buff. I then pull the last mask, clean up the area for a good fit, scrape with a razor blade and glue on.
Ken
http://www.casperguitar.com
PostPosted: Fri Jun 21, 2013 9:59 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Ken are you masking slightly smaller than the bridge????
MK5acoustics.com
PostPosted: Fri Jun 21, 2013 11:55 pm
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
If ever using tru oil on a top...Mask first!
PostPosted: Sat Jun 22, 2013 2:40 am
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
Hi Colin,
Where do you get your extra tack film from in the UK?
PostPosted: Sat Jun 22, 2013 10:40 am
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Hi Wes,
I actually put two layers of tape down on a cutting mat, lay the bridge on top and cut out the shape with an exacto knife. I'm not cutting any smaller. But I do occasionally have a little clean up to do with an exacto knife and chisel when done. I've been using this approach for the last several years with no issues.
After spraying finish, I simply remove the top layer of tape. Final film thickness prior to final leveling and buffing can also be done by throwing a caliper on the top layer of tape:
This leaves a slight ridge at the seam, which can now easily be leveled and buffed without worry of contaminating the spruce underneath:
All buffed out:
A little scraping with a razor blade, some clean up, and ready for the bridge:
Bridge is on and fits neatly in the masked area:
As you have seen, lots of ways to go about it, but this approach for me is very simple and has worked well. The trickiest part is cutting the mask. I always cut the mask and locate it on the guitar, then I double check by placing the bridge on the mask to make sure I haven't stretched the tape. It's pretty easy to remove lacquer, a little hard to add if the mask has been cut too large.
PostPosted: Sat Jun 22, 2013 10:56 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Actually on my last one I used frisquit
MK5acoustics.com
Users browsing this forum: doncaparker, rbuddy and 10 guests
