It is currently Sat Nov 23, 2024 8:02 am
PostPosted: Mon Apr 01, 2013 9:30 pm
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
I had some old templates that were made out of lexan, but the bit used to get hot and melt and instantly ruin the templates. This time, I had them made out of 10 gauge steel. I can use them to help press the top to the body. And, the bit will never get hot and these should never wear out. I had these water jetted out. Finally a cure to my template blues!
PostPosted: Tue Apr 02, 2013 9:16 pm
Last Name: Smith
10 gauge steel templates, awesome!
PostPosted: Wed Apr 03, 2013 10:20 am
Last Name: A
don't drop them on your foot !
PostPosted: Wed Apr 03, 2013 10:02 pm
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
They are very heavy. Also have to be careful not to let the bit catch on them, but that should not be a problem.
PostPosted: Thu Apr 04, 2013 2:33 pm
First name: Tony
Last Name: C
City: Brooklyn
Those templates are no good. They are for electric guitars. :-)
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Apr 05, 2013 12:56 am
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
I dont make acoustics, never interested me, and I don't feel like making the molds for them.
PostPosted: Fri Apr 05, 2013 5:34 am
First name: Tony
Last Name: C
City: Brooklyn
I was just playing around. They are nice looking templates. Should last more than a lifetime!
PMoMC
PostPosted: Fri Apr 05, 2013 6:26 pm
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
I love acoustics, and would love to have the molds and knowledge magically appear, :D .
But I can just now build an electric I feel worthy of selling, acoustics are a whole new monster and I have tons of respect for those that do it. In my opinion building an electric is much easier than an acoustic.
PostPosted: Thu Apr 11, 2013 8:44 pm
First name: Christopher
Last Name: Gaddis
City: Pensacola
Zip/Postal Code: 32533
Cool, I use acrylic sheet for templates myself, like the kind of stuff you can get from Lowes or Home Depot. Then use a bearing router bit to cut the blank. The best part about using acrylic is you can easily mod it to a different shape. Need a wider neck pocket? no problem, just glue a thin strip of acrylic to the edge of the blank with some weld-on cement from stewmac.
PostPosted: Fri Apr 12, 2013 6:23 pm
The bearings can still get hot and blow up on you. I use SAE 10W-30 to lubricate them. I have no problem with my acrylic templates either, the bearing stops spinning when it touches the template and doesn't get hot.
Old growth, shmold growth!
PostPosted: Fri Apr 12, 2013 11:29 pm
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
Friction from the bit cutting the wood causes heat which travels throughout the entire bit, bearing gets hot, melts the plastic.
PostPosted: Sat Apr 13, 2013 2:21 am
I could see that happening, but I don't seem to run into that problem.
