It is currently Tue Jul 22, 2025 10:48 am
 Post subject: Tele side banding advice
PostPosted: Sun Feb 24, 2013 11:14 am
First name: D
Last Name: S
I'm working on a Tele build out of Chinaberry.
Unfortunately I had to use several planks to get up to 1-3/4" thickness.
I'm not sure how to go about "hiding" the seam where the two boards meet.
I could leave as-is and apply a very dark dye.
I think a transition strip of banding would be best, but I don't know how to cut the groove. The edge of the body where it meets the neck has small 1/4" radius.
Perhaps I can make a scraper tool?
Any advice is appreciated.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Feb 24, 2013 12:16 pm
You didn't say how or what your finishing plans were, but you could always paint the sides a solid color.
PostPosted: Sun Feb 24, 2013 12:28 pm
First name: D
Last Name: S
Thanks Chris,
I'm using transtint dye. I reckon I can make the side nearly opaque and fade it on the top.
Kind of a single color burst.
This may be my best option, since I will have to do some major filling on the end grain.
Also, the grain between the upper and lower planks is so mismatched that covering it may be best.
I think this is the way I'll go.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Feb 24, 2013 11:34 pm
First name: David
Last Name: Morris
City: McKinney
What you're "supposed" to do is put a contrasting laminate strip between the two layers before glue up, like on a George Harrison style Rosewood tele.
I don't have a solution. I had a similar problem once. But for what it's worth, I like it the way it is now. It looks interesting. Kind of psychedelic.
David Morris
PostPosted: Mon Feb 25, 2013 7:12 pm
First name: D
Last Name: S
Yep, that would have been a good idea.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Feb 25, 2013 7:19 pm
First name: D
Last Name: S
Filippo Morelli wrote:
Can I ask why you are going to all this extra work? Is there a specific reason you wanted the two halves that way?
Filippo
Well, I used the material I had to get the thickness up to 1-3/4".
I'll have to ask my sawmill to cut me some thick slabs the next time he saws a Chinaberry log if I ever plan to make another thick guitar.
wah
Wah-wah-wah-wah
Wah
