It is currently Sat Jul 19, 2025 3:49 am
 Post subject: Go-bar material
PostPosted: Mon Jan 14, 2013 10:53 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So what type of wood works well for go-bars?
Doug
 Post subject: Re: Go-bar material
PostPosted: Tue Jan 15, 2013 4:15 am
First name: William
Last Name: Holmwood
City: Brighton
Country: England
I have very little experience but a friend of mine uses mahogany. Says it works really well.
PostPosted: Tue Jan 15, 2013 5:05 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
I use 1/4 in. slices of 3/4 boards left over from my banjo rim making. So, I wind up with an assortment of woods - maple, birch, cherry, walnut, mahogany, and some pine. Cheap and disposable when they get too short.
PostPosted: Tue Jan 15, 2013 12:14 pm
First name: Alan
Last Name: Tobler
City: Tucson
State: Arizona
Zip/Postal Code: 85748
I use whatever scrap is laying around. Most of my sticks are alder. I cut them to 5/16 x 3/4. I tried 1/4 x 1/4 but a lot of them snapped.
The dullest pencil is sharper than the keenest mind.
PostPosted: Mon Jan 21, 2013 4:57 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Mine are pine from chopped up 2x4s. its cheap so i dont feel bad when i throw a fit and break some. laughing6-hehe
PostPosted: Sat Jan 26, 2013 12:30 pm
Ash, Oak, Osage Orange, Hickory, Tan Oak, Elm. If air dried and rived they will never break, split, shatter , etc.
L.
PostPosted: Tue Jan 29, 2013 10:14 pm
First name: Josh
Bamboo garden stakes, $5 for a bag of 50. I wrap a bit of cloth tape around the end to stop them sliding.
PostPosted: Sat Feb 02, 2013 9:42 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I was just thinking about bamboo stakes for this the other day. I'll have to remember to get a bag.
Bryan Bear PMoMC
PostPosted: Thu Mar 28, 2013 9:54 pm
Last Name: Russell
State: Michigan USA
I am using 1/4" fiberglass rod from Granger Supply. It comes in 10 foot lengths and is pretty inexpensive. I started using wood strips but found each piece had a different compression which would make other bars already in place pop out. I don't have that problem since I started using fiberglass.
It only cost $6 for a 10 foot length so it is cheap. The only issue is it is not coated but a coat of bin sealer took care of that. I then dipped each end into that rubber you coat tool handles in and they are just like real Go-Bars.
Here is a link:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=fiberglass+rod&op=search&Ntt=fiberglass+rod&N=0&GlobalSearch=true&sst=subset
PostPosted: Sun Mar 31, 2013 1:07 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I use these 3/16" fiberglass rods I bought years ago from a kite supply site that someone on here recommended. The 3/16" rods work fine. I thhought the 1/4" one sold at home centers for driveway markng and such were to stiff.....Mike
http://www.intothewind.com/sessions/3b2 ... 60f/search
PostPosted: Mon Jun 17, 2013 7:38 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
http://www.harborfreight.com/3-16-inch- ... 65326.html
MK5acoustics.com
