It is currently Fri Jul 18, 2025 7:12 am
Post new topic Reply to topic  [ 130 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jan 08, 2013 3:41 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
This is going to be a total experiment for me as I can't find any information about it at all! So I'm going to make it up :lol: . It will be a small bodied, 6 string guitar. I don't even know for sure what it is called!
Body length: 380mm / 15in
Lower bout: 285mm / 11in
Scale length: 484mm / 19in
I'm trying to make it all out of wood that I already have, so the soundboard will be parana pine, neck, back and sides will be some more of that mahogany shelving of which I have stacks and the back, fingerboard and binding will be jatoba (I think). I'll probably use a carbon fibre insert instead of a truss rod, as I don't know where you could get one that short.
Pablo Picasso
PostPosted: Tue Jan 08, 2013 8:26 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
You could always make your own truss rod. They are very simple to make. All you need is some 3/16 rod, a couple small pieces of brass or steel, and a nut. I'm sure you can find plans or I can show you if you wish.
PostPosted: Tue Jan 08, 2013 9:35 am
First name: Big
Last Name: Jim
Check the lengths on Mandolin and Mandola Truss rods . You may find what you need .
PostPosted: Tue Jan 08, 2013 11:28 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Thanks for the suggestions. It looks like a mandolin truss rod would be perfect.
Incidentally, does anyone know if this size instrument has a name? I forgot to say that it will be tuned like a standard guitar with capo 5 (ADGCEA)
Pablo Picasso
PostPosted: Tue Jan 08, 2013 11:55 am
First name: Randy
Last Name: Jones
City: Santa Clara
Zip/Postal Code: 95050
Not sure how closely the dimensions match, but there is a rob and gary's piccolo guitar build series on you tube.
PostPosted: Tue Jan 08, 2013 2:28 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Yeah, that's the only place I've ever seen the bracing on one of these small guitars. It looks fairly similar, just an inch or so smaller all around.
Pablo Picasso
PostPosted: Tue Jan 08, 2013 4:53 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'll be following this one with interest. In the back of my mind, I have a terz of similar dimensions. I was thinking in the neighborhood of 16 inch long body (maybe a little wider than yours too) and 21ish inch scale depending on where I end up after I play around with bridge location. Terz would be like having the capo on the third rather than 5th fret. . .
I can’t wait to see and hear what you come up with. I liked your first challenge entry too BTW.
Bryan Bear PMoMC
PostPosted: Fri Jan 11, 2013 11:35 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Well, I have made a start. Just been pushing all my wood through the massive band resaw in college. It has motorized feed rollers and a blade about 2 inches wide! Not the best thing for cutting delicate thin sheets of wood, but it does the job, albeit with much nail-biting :shock: . The wood looks great, but the jatoba has extremely wavy grain and is very difficult to plane without tearing to shreds - luckily it's a small guitar, so there isn't as big an area.
A few pics:
Parana pine (almost perfectly quartersawn by the way!)
Jatoba
Pablo Picasso
PostPosted: Fri Jan 11, 2013 1:38 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
So then, here's the plan. I always like to draw out my designs before making them to see what they will look like. This one is rather ambitious, but I think it's doable! I'll probably change the rosette a bit though.
Pablo Picasso
PostPosted: Fri Jan 11, 2013 2:51 pm
First name: Zeke
Last Name: McKee
Nice design Peter! Thats a sweet rosette! I like that style, the one I have drawn up is in the same family. The accent purfling lines really add character, as well as the double cutaway. Before you bend the sides be sure to make your headblock, measure carfully and plan for it to be the width of your neck minus sides. This will assure your sides will blend in nicely with the neck and there will not be an odd step there. I like for it to blend seamlessly into the heel, which is why I use a heel that is wide all the way down. If that makes any sense. Its just a little detail that I find adds a lot to the guitar and shows off your craftsmanship. Just a suggestion for ya.
Oh also did you draw that by hand or use a program, it looks nice!
PostPosted: Fri Jan 11, 2013 3:21 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
I haven't decided what heel shape I'm going with yet. I might do a modified version of the one I used on my last challenge build - I really love that shape, but I get what you mean about it blending in.
I use Autosketch for all my 2D design work and Fireworks for the texturing. I scanned some of the actual pieces of wood that I'm going to use so I can really see what it will look like.
Pablo Picasso
PostPosted: Fri Jan 11, 2013 3:41 pm
First name: Zeke
Last Name: McKee
very cool ill have to look into those programs.
Of course if you are feeling like some extra work it really does not matter what shape your heel is. You can blend it to the sides. it could be tricky but its been done. here is an example
http://charlestauber.com/Guitars/Guitars_and_Lutes.html#11
PostPosted: Fri Jan 11, 2013 6:04 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Wow I've not seen it done like that before - love it. I'm guessing you would have to build mouldless, but how would you put that compound curve in the cutaway?
Pablo Picasso
PostPosted: Fri Jan 11, 2013 7:13 pm
First name: Zeke
Last Name: McKee
Never done it but my guess would be to build in a mold. Then to carve your head block to match the heel allowing for side thickness. Then you would very carefully modify the side that has already been bent and sat in the mold for a while to settle. I would carefully bend the modification on the hot pipe maybe using te carved headblock as a guide and backing support.
PostPosted: Sat Jan 12, 2013 9:06 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Minor problem #1: The parana pine stinks! I think it must have been dredged up from the bottom of a swamp laughing6-hehe
More major problem #2: The grain on the jatoba back is so curly that I can't plane the edges smooth for plate joining. How are you supposed to do this on highly figured wood?
Pablo Picasso
PostPosted: Sat Jan 12, 2013 10:20 am
Country: UK
I use a very long plumbers spirit level, attach double sided stick tape to the edge and a strip of 180 grit sandpaper.
Set up the wood the same way as you would plane it - making sure that the work surface the spirit level is on is flat and run the spirit level along the edges you want to joint.
This is the method I use most often. Make sure the surfaces are free from sawdust before gluing.
PostPosted: Sat Jan 12, 2013 10:27 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Ebony wrote:
Cabinet scrapers and sandpaper.
For the faces, yes, but you can't use a cabinet scraper to get a perfectly straight edge for jointing.
Pablo Picasso
PostPosted: Sat Jan 12, 2013 10:29 am
Country: UK
Please reread my edit. Apologies for misreading, that will teach me to get dinner ready at the same time!
PostPosted: Sat Jan 12, 2013 11:00 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Ah, that's an idea. I'll give it a go.
Pablo Picasso
PostPosted: Sat Jan 12, 2013 5:32 pm
Very cool that joint, not seen it done like that either - wonder whether he is still using the traditional claical spanish heel joint or how that works on the cutaway side... stunning stuff nonetheless.
PostPosted: Sat Jan 12, 2013 6:30 pm
Last Name: Kincheloe
Use Spanish cedar for the blocks and linings and back braces, to mask it with a better smell :) Nothin you can do for yourself while working, though.
It can be done. If your plane is ultra sharp, set to a very fine shaving, with a very small mouth opening, with a chipbreaker less than a hair's width from the edge, you can plane against the grain. And of course the plane has to be absolutely flat, too.
But for now, use sandpaper, and then inlay a solid wood backstrip at half the thickness of the back to improve the joint strength.
I wonder if a scraper plane would work well for this, too... I've been meaning to make one for ages. Got the blade and everything, but guitars are just more fun to work on than tools :P
Yeah, this picture came up on the AGF forum a while back, and he said it is an integral neck.
Here's another of my favorite styles you can do by exposing part of the integral headblock for carving:
And a variation I did on my harp ukulele, and will do again on harp guitar :)
PostPosted: Mon Jan 14, 2013 12:45 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
I've got the top joined and almost down to thickness. I love this wood (apart from the smell!). It has no hardness variation at all between the growth rings, so it's really easy to work with and I think it looks great. I also started to lay out the rosette, but I will have to make some sort of circle cutting tool before starting as I don't have a mini router to do it with.
Looking at some of my inlay wood stash to see what would look nice together.
I've made a start at thicknessing the back. Working diagonally across the grain with a very fine plane works fairly well with a little tearout. I'm going to get it close and then attack it with a belt sander to finish.
Now that it's getting smoother, the curl figure is really coming out nicely. I had no idea it looked this good [clap]
Pablo Picasso
PostPosted: Mon Jan 14, 2013 4:32 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I really like the body shape you have there. That upper bout cut compliments the other curves very nicely!
Bryan Bear PMoMC
PostPosted: Mon Jan 14, 2013 4:45 pm
First name: Zeke
Last Name: McKee
So looking at this and i was wondering is this going to be a 14 fretter? with the double cutaway you could almost pull of a 16 fret joint or so. That would really increase the playability, but i wonder if it would comprimise strength in any way? Just curious. Looking good though
PostPosted: Mon Jan 14, 2013 4:59 pm
Country: England
Looks like an art-Deco feel to the rosette layout, like it [:Y:]
Are those pieces of wood veneers?
Ed
