It is currently Fri Aug 22, 2025 12:27 am
Post new topic Reply to topic  [ 180 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Dec 20, 2012 6:35 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Jim, that's a bummer. But I'm convinced it's fixable. Get away from it for a little while and then work out several strategies. I would personally go for a new neck block with extensions an inch or so farther toward the tail under the top AND the bottom, coupled with a sliding dovetail joint. I wouldn't worry about sacrificing a little top flex, because if you can't keep the neck attached, then top flexing will be a moot point.
A block like that will be tricky to fit because the top and back are already contoured. But it wouldn't be impossible. Or you might try a tapered, squared, through-dowel as in some banjo designs, but you've probably got quite a bit more string tension at work (and not nearly as beefy a rim) as on a typical banjo.
There's a solution to this and I want you to find it. It's a pretty cool concept for an instrument and I'm eager for you to have a successful outcome.
Patrick
PostPosted: Thu Dec 20, 2012 7:01 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Some good options to consider. I hope you don't give up on it, even if you can't get it done in the next week. It's a cool idea and I hope you'll try to fix it.
PostPosted: Thu Dec 20, 2012 7:07 pm
First name: Big
Last Name: Jim
DennisK wrote:
Oh wait, it was already glued? Is there even a bolt at all? It looks like a straight tenon, so I just assumed.
Another style of permanent joint you could do is dowel pins. Glue the tenon back in, and drill holes through the back, toward the fingerboard, to where they cut half way into the tenon and half way into the headblock. Then glue in tightly fitting dowels. Ervin Somogyi does that one in his book, although drilling from the top side before gluing the fingerboard on so there are no holes visible.
Then you could glue that brace connecting the heel cap to the back, and make it wide enough to cover the holes. Or even just inlay a thin piece of wood (something really strong like ipe or African blackwood) into the heel cap and back to connect them. But only at about half the thickness of the back itself, or you'd be removing back->headblock glue area when routing for the inlay.
Dennis . I use a tennon and glue joint , then a Drywall screw to suck it down tight while it dries . I leave the drywall screw in after its set . So basically is Glued and screwed. Got the top off and the glue joint let go and broke the drywall screw . I am going to take the neck off tomorrow and change the headblock out . I am also going to Glue in another 1/8 or so strip around the inside to beef up the outside rim. Its only 1/8" now and is just to flimsy for the torque . New headblock and better neck joint and we should be in business .
PostPosted: Thu Dec 20, 2012 7:08 pm
First name: Big
Last Name: Jim
Oh Yeah , im gonna see this one through , That I promise !
Thanks for all the input guys , good suggestions all .
PostPosted: Thu Dec 20, 2012 9:07 pm
A bummer for sure. Make sure we get to hear it when you get it fixed.
PostPosted: Fri Dec 21, 2012 8:33 am
That's strange. I'm surprised it would let go like that. Dove tails are superior for obvious reasons but still an M/T joint should be good to go. What kind of glue did you use and was it old? I like the dowel idea that Dennis suggested. That ought to last a life time. Anyway sorry about your misfortune but you'll get it back together and when you do post videos because I think we are all curious how this unique little one will sound.
PostPosted: Fri Dec 21, 2012 9:04 am
First name: Tony
Last Name: C
City: Brooklyn
Well that just stinks. I hope you can work out the issues. Too bad you wont be able to do it in time for the judging though.
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Dec 21, 2012 9:41 am
First name: Big
Last Name: Jim
While I am thinking the repair through I thought I would ask , If I ship it out there , would you punch it inna face and ship it back ? laughing6-hehe laughing6-hehe
PostPosted: Fri Dec 21, 2012 9:50 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Hey Wud - try using a #8 wood screw. Drywall screws don't have much holding power, and they are very brittle, thats why they are so inexpensive. A #8 pan head with a coarse thread will hold much better. Best of luck getting this fixed - it's a nice looking instrument!
Alex
PostPosted: Fri Dec 21, 2012 11:47 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Along with Alex's comment I'll add that the drywall screw was screwed into endgrain. That further reduces it's holding power (especially if the tennon was thin). Check and see if the screw didn't pull wood out with it.
Bryan Bear PMoMC
PostPosted: Fri Dec 21, 2012 11:52 am
First name: Big
Last Name: Jim
The drywall screws purpose is to maintain the torque till the glue joint sets , its not for holding power . It works well on the Mandolins , as for pulled grain No it didnt , it was however just a poor design for the amount of torque applied .
PostPosted: Fri Dec 21, 2012 4:50 pm
First name: Big
Last Name: Jim
Why is it that , when a glue joint fails and it requires removing another glue joint . The second one holds like a freekin weld ???? [headinwall] gaah laughing6-hehe
PostPosted: Fri Dec 21, 2012 6:08 pm
Murphy laughing6-hehe
PostPosted: Fri Dec 21, 2012 11:01 pm
First name: Randy
Last Name: Jones
City: Santa Clara
Zip/Postal Code: 95050
Doh! I like the idea of treating it like an old time banjo neck into metal rod traversing the body.
PostPosted: Sat Dec 22, 2012 11:10 am
First name: Big
Last Name: Jim
I am having a bliss and a [headinwall] moment at the same time today . After pulling my work apart to determine what the issue was , I was Vindicated and felt duh at the same time .
My glue joint held ! bliss
HOWEVER when a person glues to a plywood rim that is veneered , [headinwall] all the holding power you have is the veneer duh
I am confidant now , that , a future build with a solid wood rim and this design will in fact hold up well !
I am repairing this one to work , as my prototype it wont be going anywhere , however , future builds will be made of solid wood !
PostPosted: Sat Dec 22, 2012 4:08 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Like!
Bryan Bear PMoMC
PostPosted: Sat Dec 22, 2012 5:07 pm
First name: Big
Last Name: Jim
It seems since I have a Major sinus infection and am some what contagious , my family decided in the other state that maybe I should stay home ....... Buncha Chickens !! soooooooooooo That means I have some time between meds and nap to work on the Mandola ..
We shall see , Doubt I will finish , so dont wait up for me , but I still wanna get a vid of her at least tuned and holding ... ;)
PostPosted: Sat Dec 22, 2012 5:22 pm
So you understand of course that the payment for my vote is non-refundable. I belive that is covered under section 12 paragraph 7 of the Cook County and Chicago Vote Purchasing Contract.
PostPosted: Sat Dec 22, 2012 5:28 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Wait, he paid you for your vote!?!
He blackmailed me!
I just assumed he camped out and got incriminating photos of all of us. Steven must lead a cleaner life than I do. . .
Bryan Bear PMoMC
PostPosted: Sat Dec 22, 2012 6:08 pm
First name: Big
Last Name: Jim
%&^^&^&& Contracts ! :evil:
PostPosted: Sat Dec 22, 2012 6:25 pm
Ah ha! Eureka!
I thought it sounded strange that an M/T joint would fail like that and so soon. So shoot some CA in that sucker and record a video real quick. It will at least get your entry in :)
PostPosted: Sat Dec 22, 2012 6:41 pm
Wud,
I'm sure you can find a way to get this fixed, even if you have to open it up and add a bolt or something.
I had the bridge on the Smiley-Uke fly off last weekend, a day before it was supposed to be shipped to japan. It's just a delay.
This mando will sing eventually. Hang in there...you'll find that solution. It's lookin' great otherwise.
PostPosted: Sat Dec 22, 2012 8:01 pm
deck screws and a 2x4 should hold it laughing6-hehe
Seriously, try and get it fixed. I just got over the worst cold I've had in 5 or 6 years - you can do it [:Y:]
PostPosted: Sat Dec 22, 2012 9:03 pm
First name: Patrick
Last Name: Hanna
State: Missouri
No, man. Your body is a laminated, veneered resonator. The more I think about it, the more I think you need a tapered, squared dowel stick--bearing against some beefy neck and tail blocks, because your resonator isn't as strong as a banjo rim would be. Or at least put a real beefy neck block in there and then use the M/T or sliding dovetail joint of your preference. Well...you'll get it figured out in your own time, to your own satisfaction. I'm sure sorry it went south on you. But don't give up.
Patrick
PostPosted: Sat Dec 22, 2012 11:28 pm
First name: Big
Last Name: Jim
Patrick
we are on same page my friend ...
