It is currently Tue Jul 22, 2025 1:50 am
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Oct 11, 2012 2:13 pm
georgepseifert wrote:
Hello all,
I've started building my own, but I'm wondering about how to couple the disks to the shaft. I've found at least a dozen builds on the web, but none go into any detail about that. It seems that just epoxying the disks to the shaft wouldn't be very durable.
Have you had any trouble with expansion of the disks due to humidity? Some builders recommend leaving a space between sets of disks. This seems like it could make it even harder to couple the disks to the shaft.
Any help would be greatly appreciated. Once I get over this hurdle I think I can finally get going on my drum sander and then finally on to building a guitar.
George
Hi George,
In my case, I drilled holes in the pully wheel that is used on the drum, and screwed the drum to the pully. I then drilled a small hole in the shaft where the pully set screw got in and thus secured everything in place. I did the same thing on the otherside of the drum, albeit the pully on that side was not couple to the motor.
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Oct 11, 2012 2:14 pm
First name: george
Last Name: seifert
State: Minnesota
Zip/Postal Code: 55126
Bryan Bear wrote:
I used PU glue to glue the MDF disks together on the steel shaft. I don't remember if I roughed p the surface of the shaft or not (it was about 6 years ago). I have seen no evidence of the drum coming detached from the shaft. I suppose it could happen at any time without warning, but I doubt it.
Thanks. Did you leave any gaps between disks (or sets of disks)?
George
PostPosted: Thu Oct 11, 2012 2:58 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
No. I stood the shaft upright, exactly how I have nowforgotten, but in a way that the first disk to go on would be straight (shaft plumb to the plane of the disk) and glue would not stick to whatever was holding it up. I put the first disk on with a little glue on the shaft where it would set. Then I put glue on the inside of the disk and up the shaft, set the next disk on and repeated. My drum is 25.5” (34 disks) wide so I had to work fairly quickly. After all the disks were on, I added several heavy weights to help clamp the last few disks (which didn’t have the benefit of the weight of the stack of disks). The end result was quite a lot of messy foam on the surface (easily removed when truing the drum) and no space between the disks. Thinking about it more, I may have done it in two sessions, I can’t remember for sure. I spun the drum on the sander and roughed it round then trued it to the table with sandpaper on the table. I have noticed 2 or three cracks where the MDF has split (not the glue lines) but they are so narrow that I don’t consider them to be a factor at all. So, over the span of 25.5 inches, it moved enough to open 2 or three (just wider than) hairline cracks. Plywood would probably move a bit more, but likely not enough to cause a glue-line failure between the drum and shaft. . .
Bryan Bear PMoMC
PostPosted: Thu Oct 11, 2012 3:21 pm
First name: george
Last Name: seifert
State: Minnesota
Wonderful. Thanks for the detailed explanation. [clap]
George
PostPosted: Tue Dec 18, 2012 5:30 pm
First name: george
Last Name: seifert
State: Minnesota
I finally have the thing almost finished and am trying to true up the drum. Something odd is going on and I'm getting a 0.01" to 0.015" variation every 90 degrees around the drum. Do you know how consistent your drum is around the circumference? I noticed that my motor moves about 1/8" over one drum rotation due to an inconsistent pulley I think (a new one is on order). I'm not sure if the vibration caused by the motor bouncing around is enough to cause the variations in my drum. Just curious if maybe I'm worrying over nothing.
George
PostPosted: Tue Dec 18, 2012 6:02 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Kelby wrote:
Very cool!
On the dust collection side, be very careful. A sander makes boatloads of the very fine particles that are most hazardous to your health. Your vac is doing a nice job of cutting down on the mess, but the dangerous particles are too small to be captured effectively by a vacuum. There's a big difference between suction and airflow, and airflow is what you need for the tiny particles. Until you have a good dust collection system set up, make sure to wear a good NIOSH dust mask. Keep in mind that those particles will keep floating around your shop for a long time, so opening a door to the outside and running a big fan will cut down on the amount of time you have to wear the mask after you finish sanding.
That's true if the vac filter is clean, but using a shopvac with a drum sander will clog the filter pretty quickly. Strange as it may sound, a clogged filter has better efficiency at removing small particles, as long as it's still got adequate airflow. It's not as good as a real dust collectoin system, but I was suprised at how good my shopvac works with my sander.
PostPosted: Tue Dec 18, 2012 8:04 pm
City: winnipeg
State: manitoba
Country: canada
I trued up the drum on mine by spray-gluing a strip of 80 grit to the table and raising the table to the rotating drum. It worked like a charm.
My drum is 6" dia PVC pipe with five 3/4" disks glued to the shaft. I used PU glue for gluing down flooring.
Bob :ugeek:
PostPosted: Wed Dec 19, 2012 10:19 am
Last Name: Hosmer
George
Just my belief based on experience, but I think the best course of action is to start at foundation and work your way up. We all need different levels of precision, so I can't tell you what is acceptable for your needs.
Disconnect the belt when taking measurements for runout. Record all measurements.
1. Measure motor shaft first, then the driver sheave (pulley on the motor shaft).
If you are out of tolerance on the motor shaft, either the shaft is not straight, or your motor bearings are suspect. If the shaft is OK, but the runout at the sheave is unacceptable, then you know it's time for a better sheave.
2. Check the shaft for the drum.
Typically this is done before the drum is assembled to ensure straightness of the shaft itself, but you also want to check after the shaft is inserted into the bearings. If the shaft was straight to begin with, but shows excessive runout after insertion into the bearings, then either a) the bearings are at fault, or b) the fit between the bearing and shaft needs improved.
3. Driven sheave (pulley on the drum shaft).
4. The drum itself.
Don't overlook the belt. Often the right belt can alleviate inconsistencies between the driver half (motor and pulley) and the driven half (drum assembly and pulley).
Always have plenty of sandpaper; it's rough out there!
PostPosted: Wed Dec 19, 2012 10:23 am
Last Name: O'Melia
City: Huntsville
State: Alabama
JasonMoe wrote:
I need to make one too. I like your wood on the tabletop. How dusty are these things to run? I suppose it depends on how much suction you have.
They are VERY dusty to run. But a medium sized shop vac would probably be enough to operate it.
PostPosted: Wed Dec 19, 2012 1:31 pm
First name: george
Last Name: seifert
State: Minnesota
Bob :ugeek:
How wide is your sander? Mine is 20". I can't quite imagine PVC pipe working for that length sander. It must have been hard to slide the pipe over the disks if they're any kind of snug fit.
PostPosted: Wed Dec 19, 2012 1:37 pm
First name: george
Last Name: seifert
State: Minnesota
George
4. The drum itself.
When I turn the drum by hand with the sandpaper underneath it will take down the high spots. I'm suspecting that the pulley I have where the belt rides high in one spot causing the motor to bounce a bit is setting up a vibration that is causing the problem. I suppose my wide drum (20") isn't helping. Even though it seems solid as a rock with a 1" cold rolled shaft it must be vibrating when turning at high speed.
George
PostPosted: Wed Dec 19, 2012 2:55 pm
Last Name: Hosmer
George
What type of belt?
If the belt is riding erratically on the sheave, broken cords in the belt can cause that, but I wouldn't suspect the belt until the previous items in the chain checked out OK (motor shaft and sheave). BTW, broken cords are assuming that you're using a v-belt; obviously doesn't apply to the same degree if using a linkbelt.
As to the high spots on the drum, I don't know what materials you have used, to what dimensions, to what tolerances. Yes, you can (and should) true the drum, but it's sorta putting the cart before the horse if the items before the drum are not addressed.
I feel your pain, and finding the little gremlins can truly give you fits and send you off on a wild goose chase.
The last one I built ended up using a 1.5" TGP shaft; went with that because the initial CRS didn't meet standard. Thought I was getting a good price, but the initial shaft was not straight, and the diameter was a tad on the small side for the bearings being used, causing the shaft to run in an eccentric manner. And that's after I already had everything assembled and had trued the drum. Some new words were invented that day.
Determine cause of movement at the motor and take care of that, then work your way up through the belt. Once that area is satisfied, check the drum assembly, starting at the shaft/bearing. If the shaft does not rotate to your standards, then it will do no good to true the drum. Once you know the shaft is riding OK, then true the drum.
PostPosted: Wed Dec 19, 2012 3:59 pm
First name: george
Last Name: seifert
State: Minnesota
First of all, thanks much for taking the time to work with me. Hopefully this discussion will help someone else too.
I'm using a V belt. I'm pretty sure the belt isn't at fault. I shifted the belt around while keeping the pulley still and the high spot always occurs at the same spot on the pulley. A new one should be here soon.
Unfortunately it's too late to check much on the shaft. My gauge won't reach the shaft past the disks. The shaft is a very tight fit in the bearings. I had two extra bearings at my disposal to try and they didn't help.
I used MDF for the disks.
It seems that since I can't really measure anything about the shaft all I can do at this point is take care of the vibration caused by the bad pulley. If that fails I'm probably stuck with starting over with a new shaft - or looking for a used sander. I wish I had found your instructions before I started the build. In all the builds I saw on the web (at least a dozen) it seemed like everyone just slapped the disks on the shaft, trued up the drum and ended up with a perfect sander.
George
PostPosted: Wed Dec 19, 2012 4:47 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I disagree. A medium sized shop vac will pull about 150 cfm. Supermax recommends a minimum of 600 cfm for their 19/38 drum sander and to get good fine dust collection you need 800+ cfm at the machine. You would need a 3+ hp cyclone dust collector with 6" port to get 800 cfm at the machine. But at the very least you should get a 1.5 hp "hobbyist" dust collector with a 4" port (straight to the machine, will need to open up your port wider), run a short hose, and upgrade to a Wynn Env. canister filter, all while wearing a Niosh approved respirator until safe to remove. A shop vac will be inadequate to remove the fine harmful dust and your sander will mostly likely bog down with any but the lightest passes.
PostPosted: Fri Dec 21, 2012 12:36 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Hi George,
Did you use plain cold rolled steel, or the Turned, Ground, and Polished shafting? The TG &P is made to much tighter specs, and is really the only thing you should use for shafts...
To true up my wheel, I glued some sandpaper to some MDF and ran it through the machine. Worked great.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Dec 21, 2012 7:40 pm
First name: george
Last Name: seifert
State: Minnesota
Phillip Patton wrote:
Hi George,
I used cold rolled. Somebody else, who I thought he knew what he was talking about, said that was what I should get. If I have to make another one I'll try the TG&P.
I also tried to true up my drum just like you did. Did you happen to measure just how true your drum ended up?
My new pulley should be here soon. I'll report back if the decreased vibration allowed me to get rid of the high spots on the drum.
PostPosted: Sun Dec 23, 2012 11:30 am
First name: Phillip
Last Name: Patton
City: Yoder
No, not really. My sander isn't very precise. For most things, it's ok, but I'd really like to get a "real" drum sander.
Mine sand things thinner on one side (I need to shim up one bearing) but this works great if I want to make a top thinner on the outside. :mrgreen:
Regards,
Phillip Patton
PostPosted: Sat Jan 05, 2013 12:48 pm
First name: Larry
Last Name: Hawes
I'm going to build a thickness sander and have located most materials on line (wood, hinges etc. will be easy locally).
Pillow blocks from Amazon
http://www.amazon.com/Bearing-UCP205-16 ... s_indust_5
T,G & P 1" steel rod from Speedy Metals
http://www.speedymetals.com/pc-1623-823 ... 0-001.aspx
Motor from Harbor Freight - Is 1/2 HP enough??
http://www.harborfreight.com/12-hp-gene ... 67839.html
I do not have a source for the pulleys. Where did you buy the pulleys? And is 2" at the motor and 5" at the disks the proper sizes?
Thank You and Best To All
PostPosted: Sat Jan 05, 2013 5:00 pm
First name: Larry
Last Name: Hawes
Looks like Grizzly has a NICE selection of motors. What HP is considered ideal to use with a thickness sander like Pat Hawley's design? And what RPM - 1725 or 3450?
http://www.grizzly.com/search/search.as ... 0050973296
PostPosted: Sat Jan 05, 2013 9:25 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So I just built a drum sander as inspired by this string.
I have limited space in my shop so I incorporated the sander beneath my existing workbench. Works great!
Anyone kicking this idea around needs to know how easy it really is...not to mention the $1500 one saves with this approach as opposed to a commercial unit.
Doug
PostPosted: Sat Jan 05, 2013 9:28 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
My unit is 1/2 hp, 19" wide and it seems to be plenty of power for light passes. I have a 2" pulley on the drive shaft and a 5" pulley on the drum shaft...the speed seems comfortable coming off a motor turning at 1725 rpm.
Doug
PostPosted: Sat Jan 05, 2013 10:08 pm
First name: Larry
Last Name: Hawes
LOVE the idea of mounting under the work bench. Where'd you get the pulleys? Drum shaft size? Thanks.
It seems like the 2" and 5" are accepted sizes for the pulleys, slowing the rpms at the drum from the motor's 1725 rpm, but then accelerating the rpm's from the larger diameter of the drum.
PostPosted: Sat Jan 05, 2013 10:11 pm
First name: Larry
Last Name: Hawes
dbalzer wrote:
BTW I cannot figure out how to properly upload the picture below so it fits the format of the forum. Suggestions?
Re-size the pic to 800 pixels wide - seems to be a good size for forums. You'll need a photo editing program to do so but there's tons of free ones on line. Gimp and IrfanView are two that I use.
PostPosted: Sun Jan 06, 2013 7:17 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
For pulleys try furnace repair section of Lowes or HD. I used cold rolled 3/4" for shaft and would not do anything less for sure.
Doug
PostPosted: Sun Jan 06, 2013 10:36 am
First name: george
Last Name: seifert
State: Minnesota
I just finished mine. So far so good. Mine is 20" wide with a 1" shaft. I used an old 1/2" hp motor from Menards that works fine. The motor pulley is 4" and the shaft pulley is 5". After trying several pulleys I finally found a good cast iron one at Fastenall. It was only $16. Cheaper than crummy ones I tried first.
George
