It is currently Sat Nov 23, 2024 12:20 pm
 Post subject: help, weird neck issues
PostPosted: Sun Nov 11, 2012 10:55 pm
First name: Louis
Last Name: Rodriguez
City: Bakersfield
Zip/Postal Code: 93307
Hey everyone,
This is my first post. I'm a beginner when it comes to knowing how to troubleshoot my guitar. So I decided to come on here and see if anyone could help me out. When I play on the frets closer to the headstock most of my strings (most obviously the G, E, and D) seem to fall in and out of tune. It really depends on how hard I'm pressing. If I press to hard they come up sharp and if I let up too much they'll fall flat. As I play it's way too obvious to ignore. If I could get some elaboration and some advice on how to fix it that would be awesome. Thanks you guys. idunno
PostPosted: Mon Nov 12, 2012 12:01 am
Sounds like your guitar is not in tune with itself....
And guitars should play in tune with a light touch - don't play hard just to sharp the string.
Oh, welcome to the OLF!
PostPosted: Mon Nov 12, 2012 12:11 am
First name: Louis
City: Bakersfield
well, the strings are in tune played open and just about any other position on the neck, it's just when i'm playing in anything in the first 3 frets on the neck. those are the only frets that do this. so if i wanna play an open position D maj chord, my A note from my G string just sounds terrible. same thing if i'm playing an open A chord or open E chord. If I'm playing a rhythm the tone changes within the notes are way too obvious and off putting. I'm wondering if it's a neck problem, fret problem, or an intonation problem.
PostPosted: Mon Nov 12, 2012 2:09 am
City: chicagoland
State: illinois
post a video (here) of you demonstrating the issues and i bet someone could help you....
PostPosted: Mon Nov 12, 2012 5:48 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I find that most issues at the first frets can be traced back to the nut. Sounds like some of your slots are to high causing the notes to pull sharp when fingered normally. This its due to the extreme break angle generated between the nut and the fretted note stretching the string and causing a rise in pitch. This effect diminishes as you move up the board and the angle softens. Unless you have access tho a proper set of nut slot files you may want to take it to someone and have a proper set up done, including setting the nut slot heights.
Brian
PostPosted: Tue Nov 13, 2012 7:37 pm
First name: Dan
Last Name: Smith
City: Round Rock
Zip/Postal Code: 78681
Are the frets tall jumbo style?
What guitar model are you playing?
wah
Wah-wah-wah-wah
Wah
Users browsing this forum: No registered users and 41 guests
