It is currently Sat Nov 23, 2024 12:08 pm
 Post subject: A few questions...
PostPosted: Thu Sep 20, 2012 7:41 pm
Last Name: Winkel
City: Los Alamos
State: NM
Zip/Postal Code: 87544
My first build is started, I've taken a few pics but not uploaded them yet so they will come later.
Here are my questions:
I see that people run a ground wire from their electronics to the bridge. Not sure why (maybe someone could explain), but more importantly, I'm using a Gotoh TOM bridge and I don't see any way to connect a ground to it. Suggestions?
I'm a little daunted by selecting and connecting the tone and volume controls and a switch. If I'm using 2 humbuckers, is one volume, one tone, and one 3-way switch the way to go? Should I use pots with 3/8" posts, or 3/4" posts. And are the pre-wired setups from Mojotone OK?
Last, what is the correct adhesive to use with white plastic binding?
Thanks for any help you guys give!
 Post subject: Re: A few questions...
PostPosted: Thu Sep 20, 2012 8:46 pm
The reason they ground at the bridge is because you have an effective ground at that area, and you wont hear string buzz as they call it. With your tuneomatic, you just put the ground wire in where one of the posts go, then drill a channel from there into the humbucker cavity or electronics cavity.
You can wire it however, pre-wired stuff is just fine usually.
As far as adhesive for binding, I haven't a clue. I don't do plastic binding, I use natural faux binding, and if I bind a neck it is with wood.
PostPosted: Thu Sep 20, 2012 10:57 pm
Online
A ground wire is necessary so you don't die if the guitar gets grounded....
PostPosted: Fri Sep 21, 2012 12:03 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
To glue plastic binding, 3M plastic and emblem adhesive works great. You can get it at auto parts stores. Part #08061
Jason Moe
LaCrosse WI 54601
PostPosted: Fri Sep 21, 2012 6:20 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I've always used the Weld On binding adhesive available from Stewmac. Others use Duco cement.
Kevin Looker
I'm not a luthier.
PostPosted: Fri Sep 21, 2012 9:39 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I use the glue from LMI for plastic binding.
Cost is higher than Duco,
but to me it's worth it.
I think it's better.
PostPosted: Fri Sep 21, 2012 9:56 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Will this guitar be for live performances or studio work? Simple controls are good for live performance because there's fewer things that have to be tweaked on stage. More complex may be useful in the studio.
I now prefer a single volume and tone control, it's simpler to wire and it's simpler to use. My first guitar had three single coils, two volume controls, two tone controls, and a 5 way switch. Way too much to fiddle with.
The 3/8" pots are for regular top thickness, the 3/4" are for carved top instruments like the Les Paul.
PostPosted: Fri Sep 21, 2012 5:49 pm
First name: Freeman
Last Name: Keller
I just built a LP clone, which isn't a whole lot of experience, but here is what I know
1 - I simply drilled a small hole from the bridge p/u cavity into one of the ToM post holes. I pushed a piece of my grounding wire into the post hole, spread the strands out, and when I pressed the post in I'm sure it is making very good ground contact. Btw, you may not need a ground but it is a whole lot easier to do now and can't hurt.
2 - I used the standard LP four pots, but there is a little wiring trick that makes it so that if you are on the center switch position and turn one all the way down you won't kill both pups. The wiring diagram is at StewMac's site. I also used their kit to make it easy to buy all the little pieces in one place but you can get them lots of places, including Radio Shack. In my limited experience, I find myself playing with both pups and controlling the mix with the two volumes.
3 - I used to use Duco cement for my plastic bindings (others like Weld On, they are similar). On the Lester I tried CA - it was a total cluster but actually came out OK. Would I do it again? - Not sure LOL. There is a bit of a description on post 85 and 105 here
http://acapella.harmony-central.com/sho ... Paul/page5
http://acapella.harmony-central.com/sho ... Paul/page6
Others have made their own adhesive from actetone and chopped up binding - it seems to do a pretty good job of melting the binding together but would also be a huge hassle.
PostPosted: Fri Sep 21, 2012 6:27 pm
First name: Dan
Last Name: Smith
City: Round Rock
Zip/Postal Code: 78681
It also shunts electrical noise from the human body to ground - less static and hum.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Sep 21, 2012 7:01 pm
I dont have anything to add to all the great advice already given , except that IMHO I prefer 1vol, 1 tone and a 3-way. Especially if you're new to electronics/wiring/soldering. Simpler is better all the way around, most of the time.
PostPosted: Fri Sep 21, 2012 8:25 pm
Last Name: Winkel
City: Los Alamos
State: NM
Thanks to all of you for your replies.
When I get a few minutes to myself I'll post up a few pics. So far I've made a coupla' mistakes but nothing I can't recover from!
PostPosted: Fri Sep 21, 2012 10:11 pm
You'll find if you haven't already that this is 75% of building, or thereabouts.
PostPosted: Mon Oct 08, 2012 2:26 am
Last Name: Chase
City: Ocean Beach
Zip/Postal Code: 11770-0174
eek
This is the one reason you do not want a ground wire!
If you couple your strings to the guitar's electronics and touch something else conductive that is of a different ground potential, and your amp is designed in a way that current can flow through the circuit ground (common particularly on older amps with two prong plugs, but not only these) you can get anything from a serious tickle to a severe shock to even inducing coronary asystole (a stopped heart).
Now, wiring is not what is once was and if a venue is wired properly there should be little to worry about.
I happen to do string grounds because I do a lot of recording and I need things to be quiet.
If there is a shock concern, read this...
http://www.guitarnuts.com/technical/ele ... /index.php
Most of all just be careful at venues and use common sense.
Oh, and have a blast playing your best ever!
PostPosted: Mon Oct 08, 2012 6:05 pm
First name: Dan
Last Name: Smith
City: Round Rock
I was playing guitar and my buddy handed me his bass. Zaaaap. Never hold two guitars plugged into two different amps.
Duh!
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Oct 09, 2012 2:58 pm
First name: Rodger
Last Name: Knox
City: Baltimore
I know what you mean! If everything is wired correctly, it's no problem, I've done it a hundred times. That is, I did it until I got zapped once. That was 20+ years ago, and I haven't done it since!
