It is currently Fri Aug 22, 2025 9:47 am
Post new topic Reply to topic  [ 180 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Sat Sep 01, 2012 12:43 pm
First name: Big
Last Name: Jim
I almost started gluing this up , decided to go get a sandwich and while I was out I remembered I had not cut the Stiffiner slots yet . :shock: Thank Gawd for a empty stomach laughing6-hehe
PostPosted: Sat Sep 01, 2012 1:03 pm
Good thing you remembered. I cut mine on the table saw. Looks like you were using a morticing bit?
PostPosted: Sat Sep 01, 2012 1:11 pm
First name: Big
Last Name: Jim
Yes and it does a great job . That took about 10 min set up pics and all . I dont mortise much of anything else anymore so I leave it set up .
PostPosted: Sat Sep 01, 2012 2:05 pm
I always wanted a dedicated mortiser when I was building furniture.
PostPosted: Sat Sep 01, 2012 2:39 pm
It does look oddly familiar Wud...
PostPosted: Mon Sep 03, 2012 10:20 am
First name: Big
Last Name: Jim
Glue up on neck and head stock . The neck blank is 1" thick and with the dry fit the fret board is .030 above the bridge now so I have room to move down . I am at a 1 degree slope on the neck . I will probably takke 1/8" off the neck bottom and then glue up before carving . That should allow me room to fit the bridge to the top and fret etc.
I do have one question that I would like help on ... Notice that the bridge is closer to the back of the body and leans back a little . I wondered if I could cut off first fret , change 12th fret and bridge accordingly and have a working shorter scale . Sounds to easy, so my gut says no, that the fret spacing wouldnt be correct anymore .
Comments please !!!
PostPosted: Mon Sep 03, 2012 11:19 am
It's starting to look real cool [:Y:]
I don't know why you couldn't cut off the 1st fret - nothing new there as long as the numbers and new bridge location work out. Looks like your bracing will catch the edges of the bridge pretty much anywhere you put it. I'm guessing the bridge would end up centered between the sound holes. Only issue there might be that your pinky would end up in the sound hole when you're playing - at least if you play like me (hopefully you play better laughing6-hehe ).
PostPosted: Mon Sep 03, 2012 11:36 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I agree, both that it is shaping up and that you can lop off the first fret for a shorter scale. Lay it all out before you cut and make sure everything looks okay. Measure your new scale length using the new 12th fret when you locate the bridge.
Bryan Bear PMoMC
PostPosted: Mon Sep 03, 2012 11:42 am
First name: Big
Last Name: Jim
The numbers are what im concerned about does it effectively change ANY of the fret dimensions ?
Steve , I know 5-6 basic chords and can strum a little , so basically I dont play at all laughing6-hehe scary huh
Yes it would move the bridge forward from 22.75 scale to 21.375 scale The actual distance the bridge would move forward is .625" approx
PostPosted: Mon Sep 03, 2012 1:12 pm
Last Name: Kincheloe
Nothing wrong with shortening the scale that way. May result in the neck/body joint landing inbetween two frets rather than right on the 12th/14th/whatever like guitars typically do, but on an instrument like this I don't think that matters.
On the other hand, banjos typically do have the bridge toward the back end, so it's not necessarily a bad thing. You might try tapping on it in each of the potential bridge positions to help decide which you think would sound better. My instinct is that the tone will be more "ang" with it in the far back position, and "ong" with it centered, if that makes sense :)
PostPosted: Mon Sep 03, 2012 1:36 pm
First name: Big
Last Name: Jim
This will have Mandola Strings , Not Banjo Strings . There will be 8 strings
In this instance the body to fret joint doesnt really matter , as it is its at the 16th fret and will be at the 19th fret +or- 1/6" of an inch so that isnt an issue . The player will have about 14 open frets to play befor hus thumb even touches the heel .
PostPosted: Sun Sep 09, 2012 7:31 pm
This thing looks awesome, can't wait to see and hear the final product.
PostPosted: Wed Sep 19, 2012 8:03 pm
First name: Big
Last Name: Jim
Welllllllllllllllllll I have a bit of an OHHHHH (&^&%$&*
Sanding neck to size and found a pitch pocket .
Since this is a Prototype , I am tempted to flood the area with ca and continue building . What Advice do you have ?
PostPosted: Wed Sep 19, 2012 8:31 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Press on! It will look fine. If you don't like it, burst the neck to match the resonator.
Bryan Bear PMoMC
PostPosted: Thu Sep 20, 2012 7:42 am
First name: Tony
Last Name: C
City: Brooklyn
Filippo Morelli wrote:
Wud, if this thread was half as funny as Tony's thread, you might actually be able to get the cover charge.
But seeing how it turns out to be really sucking (refer to video people if you need explanation), I'll be sending you my bill for $5 to actually show up and provide you some audience viewership.
Filippo
I'll try to add something useless but funny to this thread as well. Free of charge. However, it is early and I need more coffee before I kick into funny overdrive. For now, please accept this mildly humorous goat pic as my first contribution:
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Sep 20, 2012 8:52 am
First name: Big
Last Name: Jim
Why are you to so set on trying to get " My Goat " ?? laughing6-hehe
OHHHHHHHHH and BTW Fillippo , If acting like that guy ggets me hanging with :shock: THAT BLONDE !!! IM ALL IN !!! [:Y:] :twisted:
PostPosted: Wed Sep 26, 2012 3:11 pm
First name: Big
Last Name: Jim
A lil more neck and fretboard work . Binding and beer drinkin .
Gonna have to tint the head plate to try and match the fret board , or tint both with some black to match the ebony bridge . I have been thinking about building a bridge but dont have enough of the same wood as fretboard to do it.
we shall see idunno
PostPosted: Wed Sep 26, 2012 4:41 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
The round fretboard end and peghead seem right. I can't wait to see how they look on the round body.
Bryan Bear PMoMC
PostPosted: Wed Sep 26, 2012 8:08 pm
It's good to go with your strong points. You best be fixn' to hurry up or I'll be on my fourth before you get this done.
It was nice to see you last week, glad you made it home safe.
PostPosted: Fri Sep 28, 2012 5:53 pm
First name: Big
Last Name: Jim
Got the fret markers Glued in and ready to mount the Frets . ........ Just have this nagging feeling Im forgetting somthing . idunno
laughing6-hehe laughing6-hehe
PostPosted: Fri Sep 28, 2012 7:11 pm
Ok, something got me so I had to count. You marked ... 7, 10, 12 ... I usually mark 7, 9, and 12. Different strokes. Those sticks are going to make it hard to play chords beehive
PostPosted: Fri Sep 28, 2012 7:33 pm
First name: Big
Last Name: Jim
I have been wondering the same myself . If you check most Mandolin's ( ones I have checked , its 7,10, 12 ) I have two guitars , One is 7. 10 , 12 .... the other is 7,9,12 idunno Maybe someone will pitch in and enlighten me as well .
PostPosted: Fri Sep 28, 2012 7:34 pm
First name: Big
Last Name: Jim
Binding headplate and found enough material to make a bridge . Now all I have to do is tint the headplate to match .
PostPosted: Fri Sep 28, 2012 8:39 pm
First name: Big
Last Name: Jim
And now let it sit and cure , then scrape !!
PostPosted: Sat Sep 29, 2012 7:40 am
First name: Big
Last Name: Jim
Uhhhh Wud ... how do you play that Mandolin with them big white things stickin' out of the fretboard?
Filippo
Veeeryyy verrrryyyy carefullyyyy !!! laughing6-hehe laughing6-hehe
