It is currently Mon Jul 21, 2025 6:02 pm
 Post subject: 3-way switch question
PostPosted: Tue Dec 06, 2011 12:37 pm
I need to replace the 3-way switch on my ES-175 clone. I used a SM switch that's been troublesome. It required a 1/2" hole. I purchased a 3-way switch meant for a les paul, but it does not have enough threads for my 1/8" top. I think it is meant to be used with the rubber grommet. How big of a hole does the grommet need? Not sure if I should modify to handle this switch or try to find a different one?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue Dec 06, 2011 2:25 pm
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
They never used any grommets. I would find a switch with a longer threaded area rather than modifying the guitar. The standard threaded length seems to be 5/16".
PostPosted: Tue Dec 06, 2011 4:18 pm
First name: Daniel
Last Name: Wotton
City: Old Toongabbie
Zip/Postal Code: 2146
You can get a deep threaded nut from mojo that drops into the hole to allow enough thread
