It is currently Mon Aug 25, 2025 12:32 pm
PostPosted: Wed Nov 16, 2011 9:31 am
I bought a used spindle speeder and need to fab a stop block to attach to the spindle body. I don't want to drill and tap the spindle. A hose clamp would do in a pinch but what are the 5 holes on the two flats on the bottom edge of the spindle body for? I can't find any info in the manual on them.
PostPosted: Wed Nov 16, 2011 12:05 pm
Last Name: Garrish
They're for exactly that sort of thing, so far as I can tell. That's where Taylor mounts the plates that stop their stuff from spinning. I'm sure other aggregate head manufacturers use them for the same thing.
Bob Garrish
PostPosted: Wed Nov 16, 2011 12:23 pm
Thanks Bob.
Just out of curriosity what is the HP rating on your air spindle? Mine's only .25 and it seemed like it was lacking torque.
PostPosted: Fri Nov 18, 2011 5:48 pm
Last Name: Garrish
0.1 on mine, and I don't believe it has anything near that. You might want to ask them how they calculate the HP :)
What are you trying to do with it that requires torque? The bearings in those things die fast enough just from spinning at that speed...and sort of instantly if you 'crash' them by overloading them. I rebuild mine now, but rebuilds from the manufacturer were really expensive.
Bob Garrish
PostPosted: Fri Nov 18, 2011 10:42 pm
Cutting out circuit boards and cutting fretslots full depth - which of course I now know requires multiple passes.
I could use a couple of high speed spindles so I might run both the speeder and the air spindle once I get a little more comfortable with the machine.
PostPosted: Sat Nov 19, 2011 12:12 pm
Sheldon,
On page 20 of this pdf http://www.bigkaiser.com/pdfs/profit-ma ... df#page=28 there's a dimensioned model of a stop block that might help.
www.morganguitarworks.com
www.morgancustomguitars.com
PostPosted: Mon Nov 21, 2011 2:22 am
Last Name: Garrish
Those cuts should require fractional horsepower. You'd be looking at less than 1/20 HP if you were feeding a 1/16" cutter through PCB at full depth and 200IPM at 65,000 RPM. I know my turbines will stall at way less load than that, so the 0.1HP thing is bunk.
I think they calculate their HP values as the instantaneous amount of torque the thing can push out when it's at full speed due to the inertia of the rotor...sort of like how compressor manufacturers like to rate their compressor HP by the maximum current draw of the motor when it's starting up rather than the mechanical power.
On the topic of things that aren't questionable...what are you making PCBs for? I started messing around with electronics a couple years ago when I retrofitted the Fadal; I figured I should know what my buddy helping me was talking about :). I've cut a few boards on the machine, but now I'm setting up a printer to directly print etch resist...what will people think up next?
Bob Garrish
PostPosted: Mon Nov 21, 2011 1:37 pm
We use circuitboards on our rotary switches, toggle switch arrays and inside pickups. Nothing too fancy or complicated but it makes serviceablility easier.
