It is currently Fri Jul 18, 2025 9:07 pm
 Post subject: tilt adjust for bolt ons
PostPosted: Sat Oct 29, 2011 12:45 am
City: chicagoland
State: illinois
anyone got any practical/reasonable methods of doing this? i am tired of shimming bolt on flat mount bridge axes...........basically how do you insert a metal slug in to a neck, and what do you use as a shim screw/sleeve..?
PostPosted: Sun Oct 30, 2011 5:53 pm
First name: Mark
Last Name: Sorrentino
Are you talking about adjusting the angle of the neck? If so, that's what neck-angle routing jigs are for, or simply correct measurements on flat tops.
PostPosted: Mon Oct 31, 2011 1:01 am
City: chicagoland
State: illinois
no, i mean how to duplicate the fender type tilt system...?
i was thinking about inlaying a (sanded flat)coin into the neck heel...but the body would still need a threaded hollow insert, and matching allen screw.....
PostPosted: Mon Oct 31, 2011 9:21 am
You don't have to use a coin - find one of those slugs that electricians pop out of switch boxes.
And a T-nut would work fine for the threaded insert.
PostPosted: Thu Nov 03, 2011 7:24 pm
City: chicagoland
State: illinois
t-nut insert, great idea. wonder where i could find a headless allen bolt to match...cutting it to length wouldn't be a problem
PostPosted: Thu Nov 03, 2011 8:25 pm
You'll find the t-nut and the headless allen screw (AKA grub screw or set screw) at your local Ace hardware store.
PostPosted: Fri Nov 04, 2011 2:03 am
City: chicagoland
State: illinois
Ace is pretty awesome for unusual/quality hardware(solid copper nails and tacks anyone?).
Sears hardware stores(not the department stores) also carry nice stainless oval head screws for bolting on necks, among other things- some of the chintzy ones used in the commercial guitar world bend.
looking forward to trying this
