It is currently Sat Aug 23, 2025 7:24 pm
 Post subject: J-185 plans
PostPosted: Sat Jun 11, 2011 9:55 am
First name: Tom
Last Name: West
State: Nova Scotia
A while back there were folks who were looking for J-185 plans. I noticed that LMI is carrying such a plan. Not sure how long they have been listing it but it is there now.
Tom
 Post subject: Re: J-185 plans
PostPosted: Sat Jun 11, 2011 10:49 am
They've had them on there for quite some time I think. Just checked my email confirmation from
when I purchased some stuff from them and they've had them on there since at least 11/11/2010.
The plans are great; very detailed. The plans also give an outline to an alternative bridge design
(similar to the J-200) which I thought was nice!
I guess this was an unnecessary post from me but I've held off from not posting for a while so
thought it was time I gave my 2cents! :mrgreen:
Lewis
PostPosted: Sat Jun 11, 2011 2:22 pm
I see that it's a Scott Antes plan that is "inspired" by the Gibson J-185. Caveat emptor.
PostPosted: Sat Jun 11, 2011 3:32 pm
First name: Tom
Last Name: West
State: Nova Scotia
Howard: Do I hear you say he may over brace a tad in the plans...????
Tom
PostPosted: Sat Jun 11, 2011 5:08 pm
I haven't seen these plans. His plans for some other guitars are reputed to call for overbracing, and not to be historically accurate. And so far as I can tell, no one has ever reported seeing or hearing a guitar that he built.
Perhaps it's a great plan. But I would not just assume so.
PostPosted: Sat Jun 11, 2011 7:01 pm
The bracing on the back on the lower bout do seem rather excessive. At 19mm x 19mm (3/4 x 3/4) they definitely seem overkill.
Im not too sure what the original bracing is like on the J-185 though. I can imagine it to be fairly hefty though for being a Jumbo(ish) guitar. The top bracing doesn't seem too bad. The X-Bracing is around 8mm x 17.5mm (5/16 x 1/16) which appears to be fairly standard. I could be wrong with my limited knowledge.
I guess you would lighten or shape the bracing depending on the wood though. At least I would anyway.
When I come to finally build from the plans I probably won't be using the two lower bout back bracing dimensions. Ill probably go for a tall pyramid type bracing. Although I did do a 3/4" wide lower bout back braces for my Martin 000-16m albeit not as tall and it sounds great.
Lewis
