It is currently Sat Aug 23, 2025 3:26 pm
PostPosted: Wed Jun 08, 2011 9:46 am
Last Name: Sollod
Whats the best way to fill worm holes?
www.swiftcreekguitars.com
PostPosted: Wed Jun 08, 2011 10:07 am
In what wood?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Jun 08, 2011 10:16 am
First name: mike
Last Name: mcgrail
State: ky
What size, where, and are you trying to hide(i assume you are)? I usually just try to cut them out- but I have seen some who like the look and try to emphasize.
PostPosted: Wed Jun 08, 2011 10:35 am
First name: Tony
Last Name: C
City: Brooklyn
Using the cutoffs, make a pointy stick, put a dab of glue on the tip, shove it into the hole and snip it off with dikes. Sand level and viola! Filled hole. If it is small, you could try sanding dust and CA, but in lighter woods, that does not look so good.
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Jun 08, 2011 10:52 am
First name: Aaron
Last Name: Craig
State: Missouri
I usually use a small gardening shovel and some fresh potting soil. beehive
Aaron
Aaron Craig
PostPosted: Wed Jun 08, 2011 12:07 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I don't mind small wormholes showing on sides or backs, I think it's part of the character of the wood.
I usually fill them with black epoxy on dark woods, clear epoxy on lighter woods.
Gene
PostPosted: Wed Jun 08, 2011 12:15 pm
Last Name: Sollod
These are small holes in the back of some black limba. They (4) are quite small, about a mm or 2... I thought of making some filler with some black limba dust and LMI white glue, then fill the holes and sand. I wasn't sure if that was the best method...
PostPosted: Wed Jun 08, 2011 5:39 pm
or you can use shellac stick, and a burn in knife .. the shellac comes in a lutitus fo colours .. one of my students had to fill small wormholes in black limba, he used an dark amber stick to fill them.
PostPosted: Wed Jun 08, 2011 5:50 pm
This article on Allied's web site might help......
http://www.alliedlutherie.com/filling_a_hole.htm
Users browsing this forum: Chris Ensor and 36 guests
