It is currently Sun Aug 24, 2025 12:07 am
 Post subject: First ukes
PostPosted: Wed Jun 08, 2011 7:20 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
I've just been wrapping up my first couple of ukes and thought that I would share my experiences a bit. First, a few pics:
This one has a red spruce top, koa back and sides, EIRW binding & fingerboard, and a mother of pearl palm tree. The rosette is 3 pieces of koa with a b-w-b border. I got a whole pile of red spruce uke tops when I worked at PRS - they were too small for guitars, and fortunately for me, Paul had not been bitten by the uke bug :D ! The neck is honduran mahogany (scarfed construction). I've got another one right behind this one that is pretty much a twin, with the exception that I'm using mesquite for the fingerboard & bridge. I pore filled using LMI's microspheres (super easy application), sealed it up with a couple coats of shellac, and did about 20 coats of EM6000 for the finish. EM6000 lays on pretty thin - 20 coats is about .008 to .010" thick before leveling and sanding (after buffing, I believe I'm down around .004). I started sanding with 600 and went to 2000 before buffing (I use a Caldwell buffer).
The plan is one that I drew. I initially intended it to be a tenor uke, but I've apparently made the body more of a concert size (although it is a tenor scale). I found some info that said that tenor bodies were typically 8.25" wide and it turns out that is a bit smaller than normal. This one fit best in a concert uke case (lanikai makes some decent cases). Best practice for new body shapes seems to be to buy a case first, and then to design the instrument to fit a standard case...(duh)!
I'm a big proponent of voicing guitars, but on a body this small, I can't really say that I feel the builder has much latitude to really tune the top. I think this would have been another advantage of building to a wider/longer body shape - increased "voiceability".
The necks were set pretty similarly to how I would set a guitar neck, with approximately 1/16" to 1/8" of clearance between a straight edge on the frets and the top of the bridge.
It sounds nice and is a ton of fun to play! Guitars feel huge after playing these little things so much...!
Trev
http://www.PeakeGuitars.com
 Post subject: Re: First ukes
PostPosted: Wed Jun 08, 2011 7:45 am
That's some serious instruments you got there, thanks for sharing.
Got to love Koa!
PostPosted: Wed Jun 08, 2011 8:19 am
Nice Ukes,
I did 2 last year and hae another for this year...
Where did you get the case??
Gary
PostPosted: Wed Jun 08, 2011 9:37 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
trev what joint did you use ?? bolt on butt glue ?? and what is em 6000, finish ??
PostPosted: Wed Jun 08, 2011 9:47 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Hey Gary - the case is a Lanikai concert uke case - you can buy these from a lot of places online. It's a hard shell with a cloth exterior - they run about $35.
Ernie - I screwed and glued with a mortise & tenon joint. One of them has a threaded insert and for the other, I just used a quality wood screw. These things are so small that they are the one instrument on which I think it *may be* practical to do a compound dovetail...it's hard to get your fingers plus a tool in those little tiny soundholes...!
Trev
PostPosted: Wed Jun 08, 2011 11:42 am
Looks great!
What fret wire size did you use?
PostPosted: Wed Jun 08, 2011 12:13 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Nice Uke. I like that bridge design
PostPosted: Wed Jun 08, 2011 1:17 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
I used the standard fretwire from LMI...the bridge is also from LMI. I duplicated this bridge design for the mesquite one that I'm completing now.
Trev
PostPosted: Wed Jun 08, 2011 11:35 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Hey Parser beautiful looking uke. Make sure you come and join us guys that hang out at ukulele undergound as well.
http://goatrockukulele.com
PostPosted: Thu Jun 09, 2011 11:14 am
City: winnipeg
State: manitoba
Country: canada
The standard fretwire that Hana Lima use is size # 147. It is a little smaller but larger than mandolin fretwire.
Bob :ugeek:
PostPosted: Thu Jun 09, 2011 8:36 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Thanks guys - I'll definitely check out ukulele underground. I'm all jigged up, so I may as well make a few more... :)
cron
