It is currently Sat Aug 23, 2025 12:01 am
 Post subject: To thin?
PostPosted: Wed May 18, 2011 3:54 pm
I wound up thinning my new Black Walnut sides just below 2mm. Do you think they are sill usable?
Scott
 Post subject: Re: To thin?
PostPosted: Wed May 18, 2011 3:55 pm
Scott
If you're careful and they don't ripple much then yes you'll be ok.
PostPosted: Wed May 18, 2011 4:37 pm
I'd use them without even doubting. I often go as thin as 2mm or under for sides.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed May 18, 2011 8:10 pm
This is only the third type of wood I've bent so far. The Black Walnut bends like a dream, no ripples at all. I bent the sides at just under 2mm.
I'm sure they would have bent at 2.5 mm with no problem. I never went over 280 degrees and the whole process took around 20 minutes
Thanks again
PostPosted: Thu May 19, 2011 7:39 am
First name: Corky
Last Name: Long
City: Mount Kisco
Not too thin as long as you won't need to sand much more after bending. Are they smooth now, and will you ben bending with a Fox bender or by hand? Either way, you'll just need to be very careful and precise. Not much meat there for sanding after the fact.
PostPosted: Sat May 21, 2011 9:09 pm
Thanks Corky. I did bend on a Fox type bender and like you said after sanding I'm well under 2mm, around 1.5mm at this point.
Now I'm even more nervous about using them. Do you think using side bracing to compensate makes any sense?
Scott
PostPosted: Sat May 21, 2011 10:38 pm
One option is to bend another set and laminate them. You are at about 0.060 and that's too thin for me even with a bunch of side braces.
PostPosted: Sat May 21, 2011 11:15 pm
A simlar solution, although smaller, would be to laminate some veneer under (meaning on the 'inside' part of the side) the parts that are a little thin. Work the sides as normal, with linings and side braces if you use them, and then finish with the laminations.
Alain Moisan
PostPosted: Sat May 21, 2011 11:18 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I'd also go with a laminate.
(edit: math error!)
I don't have much experience but on my current build I bent my EIR sides at 0.080 and after rectification and inside finish sanding, i'm about 0.070. I have 5 side braces on each side and find them too flexible. I would prefer a more rigid structure but I guess it's a matter of taste.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun May 22, 2011 12:04 am
2mm is .079". That is normal side thickness in my shop.
PostPosted: Sun May 22, 2011 1:18 pm
First name: Tim
Last Name: Allen
City: San Francisco
I also mistakenly thinned some walnut sides to less than 2 mm. I had already invested time in the matching back, so I decided to try to salvage them. Laminating veneer to already-bent sides seemed fraught with ways to go wrong, so I tested laminating veneer to the side before bending. I had two scrap sides to use, and walnut veneer that would add enough thickness. I tried fish glue and polyurethane glue, clamping the side between boards to veneer. Once dry, I used a Fox bender with a heating blanket, following the procedure demonstrated in Todd Stock's tutorial. While the fish glue test side de-laminated a little bit, the test side with PU glue bent just fine, so I went with that. The completed sides are assembled and it looks like the fix will work well.
If anyone wants to try this, you should know that Gorilla brand PU glue is supposed to be inferior, and before using you should test any PU glue to make sure it's fresh enough to work.
This whole process was time-consuming, but on the other hand I saved time by hurrying through the original thinning process.
Tim Allen
"Never hurry, never rest."
PostPosted: Sun May 22, 2011 4:58 pm
2mm is the thickness I use as well. If a wood is difficult to bend I have taken them as thin as 1.6mm and been fine. I have seen historic guitars (spanish classical) that were below 1.5mm.
I have bent sets that had thin spots (I use alot of BRW that tends to be cut tight) and often will glue a layer of veneer inside prior to bending and once dry will sand or scrape to the desired thickness and then bend. Unless if the side feels weak after bending or you are afraid it will split at some point in the future, you can laminate a layer of veneer inside a bent side if you support it well. I use a side form lined with bending ply that is cut to the outside dimensions and shape of a side which I then use as a support for the bent side. When I have glued in a layer of veneer, I then use plastic bags filled with fine sand to apply pressure to the veneer since the sand bag conforms to the surface of the inside of the side.
PostPosted: Sun May 22, 2011 10:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
To thin... Or not to thin. :)
PostPosted: Mon May 23, 2011 8:23 am
Walnut bends like butter, just below 2mm as in about .075"? Go for it, my sides rarely exceed .070" in thickness and for harder woods are just about .060".
Laurent Brondel
West Paris, Maine - USA
Users browsing this forum: Bing [Bot] and 22 guests
