It is currently Mon Aug 25, 2025 12:30 am
 Post subject: 3D Pantograph
PostPosted: Tue Apr 12, 2011 2:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Some time ago, there were discussions about pantographs (2D and 3D). Just came across this and will probably go ahead and build it. Especially since I see it using the Bosch Colt!! Anybody built this one?
http://woodgears.ca/pantograph/index.html
 Post subject: Re: 3D Pantograph
PostPosted: Wed Apr 13, 2011 8:34 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
It looks like a good build but might be a little big for what I am interested in doing. I am thinking of doing the one that was discussed on the forum a while back. I have a pdf of the plan and will probably use a high speed pencil air grinder as a spindle, if I ever get to it.
Fred
Fred Tellier
PostPosted: Thu Apr 14, 2011 5:00 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
I built the one that you mention Fred with some mahogany left-overs. When a friend of mine saw it he tried to figure out what it was and then guessed it was a modern piece of sculpture. :lol:
Bill S.
Dream to be a luthier
PostPosted: Thu Apr 14, 2011 10:14 am
Last Name: O'Melia
City: Huntsville
State: Alabama
If you study the videos of this device, it's clear that it is a pseudo 3D machine since the z axis is aproxmated by angular motion. It's probaly good for an inch or two. But, a mod to the z axis part would solve that. Also, modifying the clamp to hold a pencil grinder would make it more applicable to guitar work. So, I intend to construct it with it's current capabilities as well as to add the z axis mod and pencil grinder clamp.
PostPosted: Thu Apr 14, 2011 2:13 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I built the one Fred mentioned, that was in a thread a couple of months ago. It works really
well for small inlays. I use a Foredom handpiece for the cutting. Biggest problem I've had is
learning to not move the handpiece or tracing point horizontally except while cutting. I broke
my 1/32" cutter doing that accidentally. I'm adding a "parking stand" along the back part of the
base to park the tracing point while holding the cutter off any surface.
Gene
PostPosted: Fri Apr 15, 2011 4:34 pm
Do you want the pantograph ability or the duplicator ability?
PostPosted: Sat Apr 16, 2011 10:11 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Fred where do you get a pdf of the plan?
James
James W Bolan
Nashville Tennessee
PostPosted: Sat Apr 16, 2011 10:28 am
First name: Fred
Last Name: Tellier
City: Windsor
There was a link on the original thread for the pantograph, if you can't find it let me know and I will email you the file.
Fred
Fred Tellier
PostPosted: Sat Apr 16, 2011 1:10 pm
That pantograph is very cool and reminds me of the one Rio Grande has that I've been looking at for awhile. Nice to have a set of plans.
PostPosted: Mon Apr 18, 2011 12:10 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Chris, glad you chimed in! Thought you might. First thing, I want a 1:1 scale. Second, I think it would be a simple design mod to retain the pivot capability for sign making, and then introduce a spring loaded z axis for true 3D. What do you think?
PostPosted: Tue Apr 19, 2011 7:30 pm
From what I've read the pantograph isn't used for 1:1 scale . I think it is because of the one fixed point which acts like a radius center point and the closer or farther from the fixed/center point the cutter or stylus is determines the ratio . The same for the pivot point making it 3D. If you put a spring in it to raise the pivot point up and down(which I think your mod might be) then it wouldn't be accurate at changing the scale.
I don't know if that makes any sense or not but the bottom line is you probably want a duplicator for your needs. Plenty of them out there to copy or buy or build.
You might think about building a CNC router or a dupicator built around a CNC's gantry design minus the screws and motors. Just a thought. Heck it could be used as a binding machine too. :P
It all pretty much depends on what you want to use it for to determine the size you need of either the pantograph or dupicator. Sort of a form follows function thing.
This one is a pretty nice mid size one and would be a fun weekend project.
PostPosted: Tue Apr 19, 2011 10:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I am building a CNC router. Thus pantograph will fill the need I cuurrently have, and it's cheap
PostPosted: Wed Apr 20, 2011 4:31 am
Cool, have fun with the pantograph build.
