It is currently Fri Aug 22, 2025 11:59 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Sun Apr 03, 2011 10:24 pm
Thanks for that demonstration, Shane. You convinced me. So, what are they? I'm assuming something other than aluminum, but maybe I'm totally off.
Also, when you reply to a thread about loving threads and reading threads and installing threads, I get very confused. laughing6-hehe
Mike Lindstrom
PostPosted: Sun Apr 03, 2011 10:59 pm
It's good we aren't talking about screws then!! :roll:
The inserts are zinc alloy and are plenty strong enough. If I was doing a bolt on neck I would prefer these to hanger bolts (the threaded studs) as I would not like the look of nut on the end of a bolt when looking inside the guitar, these do look clean.
PostPosted: Mon Apr 04, 2011 12:21 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
Do the threaded inserts work well with a soft wood neck, Cedar, Port orford, or do softer woods require some other consideration?
Do most epoxy these in place or use some other glue, or leave them dry so they could be replaced.
Rob
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Mon Apr 04, 2011 2:59 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Shane Neifer wrote:
Often we are not concerned enough about how good is good enough, I mean we could just have the entire neck joint made of steel (like many adjustable necks are these days) and just weld the sucker on!
Point taken, Shane, and a very valid one too.
I feel obliged to point out however, that my prior objection wasn't so much about the quality of the insert itself as the basic wrongness of threading into end grain, period. It just don't feel right.
It is just conceivable that if you repeated your experiment using end grain mahogany instead of the side grain of birch, the result might have been different.
As it happens, I also sell these same inserts as a kit, but for the purposes of reinforcing the neck joint in bolt- on electrics, Teles, Strats, and such, and they are indeed immensely strong when inserted correctly into side grain.
PostPosted: Mon Apr 04, 2011 3:26 am
First name: Peter
Last Name: Coombe
City: Bega
Zip/Postal Code: 2550
Yep I agree. I use brass inserts, but insert a 8mm hardwood dowel into the neck heel. Then you are not screwing into endgrain for that 8mm. The insert goes in very firm. Seems a no brainer to me.
Peter
PostPosted: Mon Apr 04, 2011 4:34 am
I have recently been using hanger bolts threaded into a 5/8 birch dowel inserted in the neck heel. I believe I got this idea from Mario Proulx. At any rate, I have not had a problem with it. However, I only build a few guitars and I don't do this as a profession. I've also used barrel nuts and threaded inserts and found them quite effective as well.
Under Compensated Nut!
PostPosted: Mon Apr 04, 2011 8:18 am
I use end grain zinc insert, similar to what Shane sells, as used on Bourgeois guitars (and others I am sure) and never had a problem. Notice how the barbs are on those, they bite much better on end grain than any of the others inserts. They're also much lighter than brass or steel.
IMHO there's a bit of overthinking there, the zinc alloy is plenty strong for the application, the wood will break before the threads can be damaged. In any case, they can easily be re-threaded.
I chamfer the 3/8 hole before putting the insert in and wick thin CA after the insert is in. I never had an loose or damaged insert.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Apr 04, 2011 11:57 am
First name: Matt
Last Name: Meyer
City: Muscatine
State: Iowa
Zip/Postal Code: 52761
I find it interesting that Taylor use an Aluminum dowel that has been threaded for two bolts. I think they use it to strengthen the heel and save weight. I wonder if they harden the aluminum?
PostPosted: Wed Apr 06, 2011 11:45 am
efayoux wrote:
Good stuff Shane ! to be honnest I never had concerns on the strength of these inserts - well at least not until I started reading the responses - so good to hear they are still a valid option. My question was never around the mechanical properties of these, what I was interested is if the superior sound properties of brass would make a difference in the sound transfer if used for inserts.
Eric
I really don't think anyone can make a claim that brass or al inserts will have any effect on sound what so ever. And if they do they need to provide test results demonstrating it. It's curious that a violin maker would be using inserts in the first place.
