It is currently Fri Aug 22, 2025 9:41 am
PostPosted: Mon Mar 28, 2011 9:16 pm
Hi all. I starting to make moulds and bending forms for a bunch of different guitar shapes. I want to be able to cut the mould and bending form side at the same time. So I need to know what size of bit to make this cut with. I am thinking either 3/16" or 1/4" So, what size of a "space" are you using!?
PostPosted: Mon Mar 28, 2011 10:42 pm
Shane, I am using 1/8".
L.
PostPosted: Mon Mar 28, 2011 11:09 pm
The answer really depends on the individuals bending practice. I use a slat and blanket on each side, so the difference is the thickness of the side, one slat and one blanket. Some only use one blanket, I cant say which side as Ive never done it that way. At any rate, in practice 3/16 should be about right. 80-90 for a side, Id guess the blanket is about the same and the slat is what 30ish. So that gets you in the 180ish range. Close enough if the bending form in a bit off.
And I never did a "space". I unfortunately had to make my form the old fashion way and use separate pieces. I wish I had a CNC.
PostPosted: Tue Mar 29, 2011 11:46 am
The last mould that I built was for a Martin 0000 size. I cut the pieces for the mould on my bandsaw and used a couple of the left over interior parts for the bending form. I used the OSS to clean up the cuts, which worked well. It did take a little more effort than cutting them out on a router table with a pattern cutting bit, but I'm happy with the results.
PostPosted: Tue Mar 29, 2011 5:12 pm
Similar thing here, last mold and form was for an OLF SJ.
First bandsawed to outside mold and cleaned that and inside form up with drum and sand belt sanders, then used them as templates to rout the others as required after bandsawing them.
Kept the clean ones as templates in case I need them in the future.
Users browsing this forum: Bing [Bot] and 17 guests
