It is currently Sat Sep 20, 2025 5:13 am
PostPosted: Mon Mar 28, 2011 8:40 am
First name: jeff
Last Name: scott
City: sasint john
State: new brusnwick
Zip/Postal Code: e2e 2e2
Hello all,
I just started to apply a radius block and sandpaper to my fretboard this morning ... first time build too.
Maple is hard stuff to sand. :o
Just wondering if I should cut the dimensions of the fingerboard first before sanding. Right now it is still a rectangular blank. It would seem there would be less sanding if I cut the fretboard first.
** just another note. I am taking all my measurements off a Les Paul Standard. This has binding on the fretboard. I won't be doing binding, so should I include the width of both bindings in my fretboard?
Thanks again ...
PostPosted: Mon Mar 28, 2011 10:02 am
Try purpleheart sometime for some real fun.
I would.
PostPosted: Mon Mar 28, 2011 11:07 am
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
I did mine after it was cut to width and glued on. You ought to try Ipe for real fun and games.
PostPosted: Mon Mar 28, 2011 11:55 pm
I have my necks fully shaped before I radius the fretboard to ensure that the fret plane is as regular as can be, sometimes the wood can move some after the back profile is shaped.
Old growth, shmold growth!
PostPosted: Tue Mar 29, 2011 8:54 pm
City: Tucson
State: AZ
Hand planes are good for roughing it out beehive
PostPosted: Mon Apr 18, 2011 3:48 pm
Last Name: coloccia
Country: States
I'm a little late to this party, but I'll chime in anyhow. Radiusing the fingerboard is one of the last things I do to the neck, typically the last thing I do before gluing in the neck. I don't have any deep reason for doing it like this other than I like to keep things flat and square for as long as I possibly can. For me, building a guitar is an exercise in doing very simple operations in the right order because once a straight line is gone it's gone forever. I can't tell you how many times I've wished for a straight line I ended up shaping away, so just on general principle I keep it as square as I can for as long as I can unless I have a really good reason not to.
PostPosted: Mon Apr 18, 2011 6:10 pm
^^^^^This is wise stuff, John.^^^^^
PostPosted: Mon Apr 18, 2011 11:33 pm
I'm kinda in this camp, too. One of the reasons I wait until after the frets are installed before shaping the neck. I rout for the truss rod, install it, then attach the shaped and radiused fretboard to the neck blank. I like the thick neck blank with a flat surface behind the fretboard. It doesn't require a neck rest, and it is rock solid when hammering in the frets. I also think it helps avoid back bow from compression when fretting. After fretting, i shape the neck and glue it in.
