It is currently Fri Aug 22, 2025 12:55 pm
 Post subject: ZipFlex Question
PostPosted: Wed Mar 02, 2011 10:25 pm
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Zip/Postal Code: 87114
Hi Guys,
I just installed my first ZipFlex purfling and now I need to flood it with CA.
I was watching Chris Paulick's video "Installing Top Purfling" and he flooded
it with CA, it looked like he used a medium CA. Not sure though, it was hard to see.
I have thin, medium and thick.
My question is,
What viscosity is best ??
Gregg
Gregg
 Post subject: Re: ZipFlex Question
PostPosted: Wed Mar 02, 2011 11:51 pm
Use thin CA...
PostPosted: Thu Mar 03, 2011 9:18 am
Last Name: O'Melia
City: Huntsville
State: Alabama
peterm wrote:
Use thin CA...
+1
PostPosted: Thu Mar 03, 2011 9:25 am
+2 for thin. It will 'wick' everywhere much more efficiently.
PostPosted: Thu Mar 03, 2011 10:26 am
First name: Danny
Last Name: Vincent
I don't really like the term flood. The only one I've "flooded" some what flooded the inside also. A little goes a long way with thin CA. Also, a pipette works best and try to hold the guitar at an angle such that the glue won't go into the body.
Good Luck!
PostPosted: Thu Mar 03, 2011 11:17 am
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
I just received a email From Kevin (Advanced Shell Technology) and the answer is medium, the following is part of his email.
"If you are using the ZipFlex shell purfling as one of the purfling elements, then you can apply a quick bead of Zap-a-Gap superglue (medium viscosity) onto the top of the ZipFlex (between the BWBs) to fill the gaps easily. I would not recommend the thinner Zap for this because it will just keep wicking in there and it may find a path into the interior of your guitar box."
Makes sense to me,
Gregg
Gregg
PostPosted: Sat Mar 05, 2011 1:01 am
Last Name: O'Melia
City: Huntsville
State: Alabama
+1 on medium. ;)
Last Name: O'Melia
City: Huntsville
State: Alabama
+1 on medium. ;)
PostPosted: Sat Mar 05, 2011 3:06 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I use medium CA too. Works like a charm.
Dave F.
Cambrian Guitars
PostPosted: Tue Mar 08, 2011 12:24 pm
Last Name: Tulloch
State: Vermont
I use Starbond Thin. I use the term flood too...but not literally.
Michael
PostPosted: Tue Mar 08, 2011 1:03 pm
Greg,
This is from Ryan's site instructing us to seal the edges before gluing. I'm sure you know this but just wanted to add as a reminder.
How do I glue ZipFlex into the channel?
ANSWER | You can use your regular glue since you are ultimately gluing the shell to the channel. Cyanoacrylate (superglue) has been used for over 20 years by leading guitar manufacturers and individual luthiers and it is especially suited for ZipFlex. (Be sure to seal the ledges with vinyl or lacquer sealer before using superglue to attach purflings, otherwise the superglue will wick into the end grain of soundboards and make it darker.)
philip
aka konacat
PostPosted: Wed Mar 09, 2011 8:22 am
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Hey Guys,
I think it worked pretty well,
I used medium CA, once it totally cured, (three days) I sanded it flush with 150 then hit it with 400 and then 1200.
My thinking is this: If I can get that layer of CA as smooth as possible with a nice polish/shine then when the finish is applied the Zipflex should look great.
I slightly wet it once I finish with the 1200 and I thought it looked great !!
Gregg
Gregg
PostPosted: Wed Mar 09, 2011 1:21 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
You are right. That does look great. It gives a really nice crisp, clean look up against that black binding (ebony I presume?).
cheers
Mark
