It is currently Fri Aug 22, 2025 10:47 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 06, 2011 3:10 pm
Laurent Brondel wrote:
you all tune your plates, right?
I was actually going to write that in my post but decided not to at the last moment. Here's the thing though - if you pick a tighter rad to increase strength, and then shave the braces down to get you where you were before pitch wise, you've gained nothing in terms of stiffness. You may have gained more resistance from cracking due to low humidity though.
City: Tucson
State: AZ
Laurent what are your GO sticks made of? Any specs to them at all?
PostPosted: Sun Mar 06, 2011 3:27 pm
You wrongly assume that the radius, or arch, is for strength. It is not necessarily. Stiffer, as well as lighter, does not equal better all the time.
Ash, from the tree. 3/4" x 7/32".
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Mar 06, 2011 3:47 pm
Haans wrote:
I had not considered a cylindrical radius on the back (my tops are 15' cylinder), but that may be an interesting experiment. However, I wouldn't expect much difference as I mostly operate on an intuitive level and stop working a back when it sounds good and then work the whole box when it's together.
I use a mostly cylindrical back plate and add a tiny longitudinal arch to prevent the back from caving in when it's too dry. I agree that it does not make much difference. There is a lot of over-thinking about back or top radius: no matter what the radius is, you all tune your plates, right? So any difference a tighter radius will make is compensated (intuitively I should add) by either thinning the plate further and/or bracing.
However, for maximum strength, the back should be arched laterally and left flat longitudinally, like the section of a tube.
So a regular radius dish shouldn't be used when building a longitudinally flat back? What do you use?
I don't use dishes, but a long board with a 5' (or so) lateral arch.
I didn't think so.
I haven't used them for the back either.
PostPosted: Sun Mar 06, 2011 4:08 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I did my back radius sanding block with 3 pieces of 1'' MDF, carved a 16'' radius on the top of them, then screwed down a 3/16'' plexi on it. Double-side tape and a good 100 grit sandpaper. That simple. The 3/16 plexi gives the perfect rigidity for the job.
And by the way, to get an accurate radius, I took a 16'' chain, attached a pencil at the end, then went up a stairwell to draw the arch on a masonite. (i'm not joking [:Y:] )
I have photo of all that if somebody want.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun Mar 06, 2011 4:09 pm
I assumed nothing - I was just stating a fact for people to think about. In a prior post though, you did write this:
Because it is under tension it is theoretically possible to use a thinner back for equal strength (to a flat one).
PostPosted: Sun Mar 06, 2011 4:28 pm
Seriously Andy, note the "theoretically".
Secondly, even if a shallow radius adds marginal strength to a plate, it is not its primary purpose. Its primary purpose is to allow the back to become flatter when exposed to lower RHs, instead of caving in and crack.
Laurent Brondel
PostPosted: Sun Mar 06, 2011 4:40 pm
Laurent, I'm not disagreeing with you! :P
You're not the only one posting on this thread though - My first response was to John who stated:
bluescreek wrote:
Not one ever said the back radius was anything more than a strength provider.
PostPosted: Sun Mar 06, 2011 7:44 pm
The radius back will have more strength ( stiffness ) than a flat back. That is a fact. It also does help with RH changes and allows cross grain movement to a degree.
PostPosted: Sun Mar 06, 2011 7:50 pm
The easiest way to make a kinda cylindrical (I forget the name...Howard?) sander for ribs and back or top is to get some 1/4" ply and nail it down in the middle. Jack up the ends with a couple of sticks and you have it.
PostPosted: Sun Mar 06, 2011 8:29 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
You can stab a potato with a freakin drinking straw, and it will penetrate.
If you flattened out the straw,
it would bend.
So, cylindrical is stronger, end to end.
PostPosted: Sun Mar 06, 2011 10:13 pm
That's only true (the first part) when all other things are equal. If you shave down the braces because you put a tighter radius in the back to bring the tap tone back down...well then you're not that much stronger now are you?
PostPosted: Mon Mar 07, 2011 10:00 am
That's the way I do it, except I use hardboard. That would result in a spline curve, and not a perfect radius (to answer for Howard).
I responded because you quoted me twice in your post.
Except trying to stir up controversy, I have no idea what your point is. John, I and others have responded and seem in rough agreement.
Laurent Brondel
PostPosted: Mon Mar 07, 2011 10:25 am
Actually,I just went back and re-read this thread and I see that I mis-read one of your posts and basically re-stated what you wrote in that post. Sorry about that. What I don't understand is why you disagreed with it when I re-stated the same thing you did.
PostPosted: Wed Mar 09, 2011 5:21 am
The differences in the radii of 15' and 20' are about 3/64th(.0467) over that distance of an 18" back. Hardly discernible, either tone wise or mechanically.
