It is currently Tue Nov 26, 2024 11:47 am
 Post subject: New Build...
PostPosted: Fri Mar 04, 2011 2:12 pm
First name: sean
Last Name: loughney
City: lackawanna county
State: pennsylvania
Planning stages.
Do you suppose this semi-hollow design will work as far as not feeding back? Is there a formula or a certain rule to follow when designing? I figured if the control cavity is separate from the chambers it would work. Am i wrong in assuming this? would there be any tonal differences between this and making it one big chamber?
or this one (my first idea of the chamber)
Thanks for any suggestions.
 Post subject: Re: New Build...
PostPosted: Sat Mar 05, 2011 2:55 pm
First name: Mark
Last Name: Sorrentino
Copper foil the whole cave perhaps?
PostPosted: Sat Mar 05, 2011 4:13 pm
Last Name: D
State: CT
i remember seeing Filippo using a paint on a prs build he did. maybe he will read this and tell you about the pros and cons.
PostPosted: Fri May 27, 2011 9:45 am
First name: sean
Last Name: loughney
State: pennsylvania
PostPosted: Fri May 27, 2011 11:26 am
I built something similar with two chambers many years ago. The current owner has never complained about feedback troubles. In fact, he still thanks me for building it every time we talk. I didn't foil it, or use shielding paint. The Duncan pickups have been quiet enough.
PostPosted: Fri May 27, 2011 11:38 pm
If the pickups are on a solid area you won't have any troubles.
PostPosted: Thu Oct 17, 2013 8:49 pm
First name: sean
Last Name: loughney
State: pennsylvania
Getting back to it after waaaaaay too long. I have lost/misplaced my tailpiece since I took the top photo. The stain that I used on the body is getting sanded off and reapplied later. Im really looking forward to getting this guitar finished. Ive missed building. bliss bliss bliss pizza
