It is currently Fri Aug 22, 2025 10:18 am
 Post subject: Off-topic glue question
PostPosted: Sat Feb 26, 2011 10:16 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I am making a wood whitewater kayak paddle. I used epoxy to glue the strips together, and while I was shaping the blade with a DA one of the joints separated partially. The joint is koa and willow. Should I use superglue or epoxy? The blades will be covered with fiberglass. I have been banging wood paddles on rocks for years and have marveled at how much abuse they can take without breaking. I'm sure that most of the strength comes from the fiberglass, but I would like to repair this joint the best way possible.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sun Feb 27, 2011 12:00 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I'd use epoxy because it has superior gap filling properties.
PostPosted: Sun Feb 27, 2011 11:31 pm
Use epoxy and most of the strength comes from the resin not the fiber glass.
L.
PostPosted: Mon Feb 28, 2011 7:59 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Thanks!
