It is currently Fri Aug 22, 2025 2:18 am
 Post subject: dewaxed shellac source.
PostPosted: Tue Feb 22, 2011 3:09 am
Where is a good place to get flake form 100% de-waxed shellac suitable as a sealer for underneath KTM- SV?
thanks
PostPosted: Tue Feb 22, 2011 6:19 am
First name: Tom
Last Name: West
State: Nova Scotia
Wood Essence has flakes if you are interested in making your own mixture.They have good product and good to deal with.
Tom
PostPosted: Tue Feb 22, 2011 11:08 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Shellac.net
PostPosted: Tue Feb 22, 2011 11:18 am
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
I get mine from Jeff Jewitt at Homestead Finishing.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
PostPosted: Tue Feb 22, 2011 12:20 pm
LMII has it too.
Or you can use Zinssers Seal Coat or Spray Shellac. Those two are de-waxed.
PostPosted: Tue Feb 22, 2011 1:29 pm
First name: Mark
City: Concord
Vijay is my source:
http://www.shellacfinishes.com/Shellac.html
PostPosted: Tue Feb 22, 2011 3:12 pm
I have a pound of dewaxed superblonde on the way. I tried the Zinsser stuff and had adhesion issues. I was able to peel off the bridge area like a decal, which was very convenient but nit very reassuring. This was with both the aerosol, and the premixed stuff through a Preval. I'm hoping fresh mixed stuff saves the day.
As an add-on question, can isopropyl rubbing alcohol be used as a mixer?
PostPosted: Tue Feb 22, 2011 3:32 pm
I've heard of people using it, but not very effectively. Too much water. If you were having adhesion problems with Zinsser, there was something else going on. That's what I use when I'm working my tops, and it sticks like crazy, and I tape to it, with no issues, or peel up problems.
PostPosted: Tue Feb 22, 2011 3:34 pm
The issue was not making the shellac stick to the wood, which it did, but making the SV stick to the shellac.
PostPosted: Tue Feb 22, 2011 4:04 pm
Just wondering, did you use "Zinsser Shellac" or "Zinsser Seal coat"? I've had issues with zinsser shellac (which should NOT be used as a sealer - indeed adhesion issues) but all seems fine with the Seal coat.
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Feb 22, 2011 4:14 pm
The regular Zinsser shellac is not de-waxed. Only the Seal Coat and the Spray.
PostPosted: Tue Feb 22, 2011 5:23 pm
Same problem with spray and Sealcoat.
PostPosted: Tue Feb 22, 2011 5:37 pm
Well, now I know that KTM-SV doesn't stick well to the Zinsser stuff! For myself, I'm using polyurethane. Like I said, I only had issues with Zinsser Shellac, but the Seal Coat worked well for me.
Alain Moisan
PostPosted: Tue Feb 22, 2011 6:28 pm
Frankly I would not base your decisions on my very limited experience with spraying. I am following a recipe that others have used successfully for a long time, so now I am just trying to reduce variables. I cannot attest for the shelf life of the shellac I used, either the premixed sealcoat or the spray can. So don't throw out the baby and the bathwater based on my singular result. I am really hoping to find how to make SV work for me as I think it's great stuff. It's just now a matter of finding out what is causing my particular set of kerfuflicities.
PostPosted: Tue Feb 22, 2011 6:31 pm
it may be in your prep. if you sand much beyond 220 grit you can get the wood too smooth for things to stick .
PostPosted: Tue Feb 22, 2011 6:46 pm
The problem is not getting shellac to stick to wood, but to get the SV to stick to the shellac... Wood was prepped to 220, shellac scuffed with a...a...a...scuffy pad.
PostPosted: Tue Feb 22, 2011 10:51 pm
Wood Finishing Enterprises.
Great to deal with, and great fun to brouse thru all the wierd stuff he has.
PostPosted: Wed Feb 23, 2011 3:14 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Tarhead
Post subject: Re: dewaxed shellac source.
First name: Mark
City: Concord
Vijay is my source:
Me too.
