It is currently Fri Aug 22, 2025 7:58 am
PostPosted: Tue Feb 01, 2011 11:19 am
I built this over the weekend to help save me some time carving necks and bodies.
PostPosted: Tue Feb 01, 2011 12:11 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Now that's something I'd like to have ........ do you have any plans? How do you mount the neck (s) to the table?
PostPosted: Tue Feb 01, 2011 12:23 pm
I didn't use any plans Corky. Just used drawer slides and hinges to get the movement for carveing. It's real simple to make. I'm going to build a desk top one for inlaying my headstock logo and fretboards that will be easier to move around in the shop. I will be useing double stick tape with some de-staco clamps to keep everything still while carveing. ;)
PostPosted: Tue Feb 01, 2011 12:29 pm
Quote:
What have you done to save time?
I jiged myself up to the neck. And I try to use powertools as often as possible.
I also try to keep my design features simple. (No complex perflings, very simple inlays, for example).
I couldn't use a duplicarver for necks since my neck shape and specs change from one customer to another.
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Feb 01, 2011 7:24 pm
I think about guitar design while I'm walking the dog.
PostPosted: Tue Feb 01, 2011 7:28 pm
How are you compensating for the offset in tool diameter? The picture appears to have two different tool diameters showing?
MK
I'm outside looking in, just farther from the window than most.
PostPosted: Tue Feb 01, 2011 7:33 pm
I just stuck those 2 in there for referance. They do have to be the same diameter. I'll be useing 1/4" on both sides most the time.
PostPosted: Tue Feb 01, 2011 7:35 pm
Okay, :) I was just wondering :) Otherwise the pockets would have been 1/4" oversize .
Thanks for clearing that up. :)
MK
PostPosted: Tue Feb 01, 2011 7:51 pm
That's pretty efficient, but I think about it in my sleep.... ;)
PostPosted: Tue Feb 01, 2011 9:03 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I study full-time (lutherie school), work part-time, and try to have a life between this all.
The only way I found I can save time is to sleep less. Bad.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Wed Feb 02, 2011 12:10 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
i try to,
ummm,
I ferget.
Oh!
I remember now!
I try not to save time when building guitars.
I try to spend more time on that.
PostPosted: Wed Feb 02, 2011 1:27 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
What kind of laminate router is that and does it work well. Looks like a nice poor man's version of a CNC machine. Thanks for sharing.
PostPosted: Wed Feb 02, 2011 5:31 am
If we only knew what the dog thinks about.
Filippo
"Blah, blah, woof, woof Howie".
I've tried, but the older I get, the faster time runs away from me...
PostPosted: Wed Feb 02, 2011 8:47 am
That's a cheap Harbor Freight router. I have 3 of them and they do a good job for the money. You don't need an expensive one for this machine because you are going to finish sand after anyway. I keep my better routers for binding and rosette work.
PostPosted: Wed Feb 02, 2011 9:21 am
Drive fast, and chug beer (not all at the same time, thats NUTS).... and I PVR TV shows so I dont have to watch the commercials ...
and I stopped walking the dog ...
PostPosted: Wed Feb 02, 2011 3:03 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Very cool - I can't tell from the picture - is there a vertical slide as well, to duplicate the depth of the template, or does it only carve outlines of the template? Thanks.
PostPosted: Wed Feb 02, 2011 4:23 pm
Last Name: Garrish
Filippo
"Tomorrow I get to poop again!"
It's totally true.
Simple desires are the road to happiness :)
Bob Garrish
PostPosted: Wed Feb 02, 2011 5:50 pm
It goes up and down and can carve a 3D copy. If you look at the pic. you can see the brass hinges to allow up and down movement. Hope this helps Corky.
PostPosted: Wed Feb 02, 2011 7:13 pm
Filippo
It's totally true.
The dog thinks not about tomorrow, Bob. I am quite sure of this. Living in the present is one of their great lessons.
PostPosted: Thu Feb 03, 2011 12:49 am
First name: David
Last Name: LaPlante
Well said Howard.
PostPosted: Thu Feb 03, 2011 2:47 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
One thing I did as a beginner, was to get multiple tools. Like sanding blocks with different grits of sandpaper, so you don't have to change papers. Or get a couple dremels so you don't have to change bits and settings. I wish had more money to get another bandsaw. So I would'nt have to take the time to change blades.
Jason Moe
LaCrosse WI 54601
PostPosted: Thu Feb 03, 2011 7:41 am
I try to do the same thing Jason. I need to get another bandsaw as well. They are very useful and changeing the blade is more time consumeing than most other machines.
PostPosted: Thu Feb 03, 2011 1:34 pm
First name: Nelson
Last Name: Palen
What have I done to save time?
I read the OLF to get wonderful tips on better tools and methods to save time.
PostPosted: Thu Feb 03, 2011 3:09 pm
+1 I agree. There's alot of good info here on the OLF [:Y:]
PostPosted: Thu Feb 03, 2011 6:46 pm
Quit building guitars. duh
Users browsing this forum: Bing [Bot] and 7 guests
