It is currently Thu Aug 21, 2025 7:12 pm
 Post subject: Scraper sharpening tip
PostPosted: Wed Jan 12, 2011 12:17 pm
Country: Romania
I'm sorry if I just rediscovered the wheel, but here it goes anyway.
Normally, one prepares and sharpens the scraper on stones then turns a hook with a burnisher. When it gets dull, the hook can be resurrected by burnishing one more time. IME trying this a second time (a total of 3) doesn't give any usable result. It's time to bring it to the stones again.
Well, the trick is to "burnish" the third time using a fine cut file the same way as using the burnisher, at a small angle (say 80 between scraper and file). This seems to sharpen the hook a fair deal giving a few more good minutes of work. Of course it is not the smoothest shaving as given by a fresh hook but it does cut a solid shaving instead of dust.
Hope this might be useful to some of you. At least for me, truing a scraper is such a drag, unlike the poetry of doing a Japanese plane iron and stuff like that :)
Build log
PostPosted: Wed Jan 12, 2011 2:13 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
If you are trying to raise the hook for the second or third time, you need first of all to to lay the scraper flat on the bench, and run the burnisher along the edge, prior to raising the hook.
You won't get a satisfactory hook second or third time round just by burnishing in the same way as you would do with a freshly stoned edge.
PostPosted: Wed Jan 12, 2011 2:20 pm
Country: Romania
Thanks, I'll try that!
Build log
PostPosted: Wed Jan 12, 2011 4:41 pm
Last Name: Kincheloe
I never have gotten good at turning a hook on a scraper. Gotten it great a few times, but now I just use the method from Ervin Somogyi's book, where you polish up the faces near the edge, and then clamp it in a vise and run a file along the edge a few times to make a sharp 90 degree edge on each side. No hook, just use the 90 degree edge directly. Way easier, shaves plenty fast, and only takes a few seconds to resharpen so you can do it every couple minutes for an always-fresh edge :)
PostPosted: Wed Jan 12, 2011 4:44 pm
Yup ;)
PostPosted: Wed Jan 12, 2011 5:01 pm
Country: Romania
Dennis, from what I saw so far, getting a great hook depends heavily on having a very well stoned edge, very sharp and nicely polished. If you run your finger on it and doesn't feel like it is able to cut you off, it won't take a nice hook. When it is perfect, the hook is small but effective, and can be created with little, and light burnishing. At least for me it takes a good deal of elbow grease to reach that state though. Often I stop the stoning somewhere midway then resort to harder and longer burnishing to turn a hook, which of course doesn't work that nice. Anyone knows a good shop that sells patience?
Build log
PostPosted: Wed Jan 12, 2011 5:05 pm
All this effort may not be necessary for other than finsih work. Richard Brune once showed me that he lays the scraper down on the support in front of a grinding wheel and runs it back and forth quickly at 90 degrees to the wheel. It is then ready to use with the burr remaining from the grinder. He scraped large amounts of wood immediately.
PostPosted: Wed Jan 12, 2011 5:12 pm
Alexandru Marian wrote:
...Anyone knows a good shop that sells patience?
I generally have a rather large stock of patience but with the last two guitars I've build, my stock is nearly depleted so I can't sell you any. Mind you it's rather costly and the shipping over to you would be rather expensive :D mind you, I could really use a nice trip to Romania :D
PostPosted: Wed Jan 12, 2011 5:27 pm
Country: Romania
Sure, I'll guide you in the Carpathians and harvest some blood-red spruce from Dracula's castle hill laughing6-hehe
Build log
PostPosted: Wed Jan 12, 2011 5:36 pm
Here's my take. Draw file and forget trying to stone the entire edge. If you want to take out the scratches left by the file it's much quicker to draw file with something finer - silicon carbide glued to a piece of wood. We only tend to use the central part of the scraper anyway. Trying to true the entire length of the scraper seems a waste of time to me. Then it's just a case of removing the burr in the normal manner.
PostPosted: Thu Jan 13, 2011 10:43 am
First name: Chuck
Last Name: Gilbert
I learned a method from Charles Fox that's similar to what Dennis describes above. Use the file in the same way, but with the scraper still in the vise, use a burnisher (you can actually use a round screwdriver shaft - I use an old knife sharpener like chefs use) to turn a hook by running the burnisher along the edge of the scraper holding the burnisher at a slight angle. Takes 30 seconds and works like a charm.
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
PostPosted: Thu Jan 13, 2011 11:47 am
That's the quick and dirty method, but you get a rough burr that doesn't last long. A well sharpened scraper is a different experience.
PostPosted: Thu Jan 13, 2011 1:00 pm
I have the impression that the hook lasts longer if you consolidate the edge by passing the burnisher flat along the edge before forming the hook by angling the burnisher.
PostPosted: Fri Jan 14, 2011 2:28 pm
Hey Alexandru, have you seen this scraper jointer thing from LV? I have one and think it's a "cool tool."
http://www.leevalley.com/US/wood/page.a ... 31&p=32631
regards
pvg
PostPosted: Fri Jan 14, 2011 7:13 pm
Here's a trick I learned online and works quite well, believe it or not. First I true up the faces and edge on a coarse continuous diamond stone, very fast. Then I burnish, first with a few strokes at 90 degrees and then at the angle I want. Then I scrape an MDF board, about a dozen long strokes. Then I burnish on an angle again. With this I get nice shavings, no dust. It appears the MDF polishes the edge. Go figure.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 7:47 pm
Yes, I do something similar. Run the scraper along an edge sander. Instead of at a 90 degree angle and rolling over two burrs I hole it at a 45 degree angle and roll over one large burr. For scraping rosewood and other rough stuff it works great. If you ever want to do finishing scraping then I use stones to hone it and get a less jagged edge. Seems to me I did a Luthier Tips du Jour video once on this.
PostPosted: Fri Jan 14, 2011 7:51 pm
MDF is pretty rough on tools, but I think that is the point. It removes the jagged edge. It's still a bit weird, but it works well.
Randy Muth
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 7:52 pm
One more thought, I think it just acts like a very fine abrasive, like using a fine stone.
Randy Muth
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 7:55 pm
Lots of different ways to do essentially the same thing. Brian Boggs has a nice little video on the Taunton website http://www.finewoodworking.com/PlansAnd ... px?id=5233
PostPosted: Fri Jan 14, 2011 8:12 pm
City: Tucson
State: AZ
Man that MDF method is intriguing, I'll have to try that tomorrow.
PostPosted: Fri Jan 14, 2011 8:14 pm
Ian, let me know how it works for you.
Randy Muth
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 8:45 pm
City: Tucson
State: AZ
Certainly will
PostPosted: Sat Jan 15, 2011 4:06 pm
City: Tucson
State: AZ
I did a scraper this morning. Ran it across a file, burnished it up, scraped some MDF, burnished it again. wow. Works crazy well. I got plane shavings from the thing after. I was using my thickest scraper.
PostPosted: Sat Jan 15, 2011 5:18 pm
Wow, so it even worked when using a file. I use a diamond stone which is about P360. I'm glad it worked for you.
Randy Muth
Facebook Fan Page
Users browsing this forum: gregorio and 12 guests
