It is currently Fri Aug 22, 2025 8:19 am
 Post subject: Re: Lucky Strike?
PostPosted: Thu Dec 23, 2010 1:38 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I've only seen 2 LS tops but neither were very stiff at all - although the grain
was pretty consistent.
PostPosted: Thu Dec 23, 2010 2:59 am
Even a few degrees off quarter can have a pretty big effect on cross-grain stiffness in redwood. Could that account for it?
http://www.chassonguitars.com
PostPosted: Thu Dec 23, 2010 8:21 am
The LS tops I have seemed really stiff, but it's been a while since I handled them, and I haven't taken any close to final thickness yet. The grain's real consistent, though, I think. I need to get set up with a deflection test rig, it'll be interesting to compare.
PostPosted: Thu Dec 23, 2010 9:43 am
I have one LS top in my shop. The grain count does vary somewhat... 20 near the edges to 35-40 in the middle. It is incredibly stiff however. Stiffer by far than the other redwood tops in my stash. Stiffer than most of the spruce tops I have too, for that matter. I was planning on going .110-.115 with it. Certainly no thicker than .120. I think your comment about about top variance well taken. Best to work each top based on it's own characteristics instead of broad generalizations.
Jim Womack
Will Rogers
PostPosted: Thu Dec 23, 2010 9:58 am
The LS sets I have are very stiff in both directions, they are nicely quartered.....great taptone too.
Greg
Gwaltney Guitars
PostPosted: Thu Dec 23, 2010 2:20 pm
First name: Hugh
City: Lake Oswego
State: oregon
Not to sound entirely unaware, but LS-lutz spruce?
PostPosted: Thu Dec 23, 2010 2:22 pm
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
http://theunofficialmartinguitarforum.y ... ofile.html
Bobby Masten
PostPosted: Thu Dec 23, 2010 2:31 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Hugh,
Here ya go brother. It's redwood wood. It's called the Lucky Strike Redwood.
Here be a link:
http://www.guitarbench.com/2009/11/04/t ... d-profile/
hope this helps,
Hutch
PostPosted: Thu Dec 23, 2010 4:58 pm
First name: Marc
Last Name: Johnson
City: Mars
State: PA
Zip/Postal Code: 16045
Todd,
Check with Lance. He has, and has had a pretty good supply of LS Redwood tops. He reserves them for his OMFS and E2 models only. Maybe he could add to the already good responses you've already received.
Happy Holidays,
Marc
PostPosted: Fri Dec 24, 2010 8:34 pm
I have 8 LS tops left. Never had any that were floppy cross grain. Mine are consistently stiff cross grain and very even consistent grain count with LOTS of silking all the way across the face. As someone else mentioned redwood is very finicky and will go limp cross grain if a few degrees off 90*.
tim...
PostPosted: Fri Dec 24, 2010 9:31 pm
same here....
