It is currently Thu Aug 21, 2025 4:09 pm
 Post subject: UTB Brace width
PostPosted: Wed Dec 22, 2010 9:02 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I have been generally following the Grellier OM dimensions for brace widths - 8mm (5/16) for the UTB and X-Braces, 7mm for the TB's and 6mm for the finger braces.
In some recent posts with bracing pics I noticed people using much wider UTB's.
I went back to my Cumpanio book and see he recommends a 1/2" wide UTB (or, as he calls it, the "upper face brace").
Do you think for:
- an OM size, 14-fret guitar,
- using light strings,
- with a 1/4" hole in the UTB by the soundboard for truss rod key access
That a 8mm (5/16) x 16mm (5/8)" UTB is sufficient?
(it is Lutz Spruce)
 Post subject: Re: UTB Brace width
PostPosted: Wed Dec 22, 2010 9:14 pm
First name: Tom
Last Name: West
State: Nova Scotia
Robbie: I generally make mine 5/16" by 3/4" and never go under 3/8" when scalloping the ends.Quite often I leave a 3" section the full 3/4" and then straight taper down to 3/8" on the end to tuck into the linings.
Tom
