It is currently Thu Aug 21, 2025 12:51 pm
PostPosted: Thu Dec 16, 2010 3:25 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
I purchase my fingerboards from LMI - and I have them service them for me - which means radiusing and slotting them.
I'm looking for a good/quick/repeatable way to taper the fingerboards. I don't have a table saw, but have a 12" Craftsman (newer) band saw.
When I tried making a jig for my router setup, straight cut bit and bearing, I had problems with chipping of wood on the fret slots.
I tried cutting the taper on my band saw - but my cut was less than straight, which required a lot of work to get the fingerboard to the point where I could bind it.
I'd love to hear/see ideas on how to do this better/easier.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Dec 16, 2010 3:35 pm
Paul,
Time to get a table saw. Then you can make a sled to do this easily.
PostPosted: Thu Dec 16, 2010 3:38 pm
Steve Saville wrote:
Paul,
yep! Can't get any better than a good table saw....
First name: Tom
Last Name: West
State: Nova Scotia
Paul: I just cut mine on a band saw and true up with a long handplane or on the jointer. Be careful of grain direction and in most cases plane from large to small.Use a bevel protractor to make sure slots are perpendicular to centre line of board. Lots of folks use a jig on the table saw. The same jig could be used on bandsaw and again clean up with hand or power tool.
Tom
PostPosted: Thu Dec 16, 2010 3:40 pm
First name: Tom
Last Name: West
State: Nova Scotia
Some of you guys type fast. Thought I was first in line....!!!
Tom
Last Name: Sollod
Steve, Can you show us a picture of your table saw jig?
www.swiftcreekguitars.com
PostPosted: Thu Dec 16, 2010 3:42 pm
Last Name: Ulman
City: Bellevue
State: Washington
I did it essentially like Filippo and Tom… I marked the taper using a white pencil, free hand cut to within about 1/8 inch on the bandsaw, hand planed down to outside edge of the lines with a No. 4 and made the final few passes with a No. 7. It came out perfect.
Joe
PostPosted: Thu Dec 16, 2010 3:55 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
Paul,
I made a tapered jig to cut close to shape on my bandsaw, then I run it down my router table with a straight cut bit a few times to get it straight and smooth.
Chris.
PostPosted: Thu Dec 16, 2010 7:46 pm
Bandsaw rough and take it down on the old 6 X 89" belt sander...bout half a minute.
PostPosted: Thu Dec 16, 2010 8:02 pm
Bandsaw and a handplane here too.
PostPosted: Thu Dec 16, 2010 9:40 pm
Another bandsaw and handplane here
PostPosted: Thu Dec 16, 2010 9:47 pm
Bandsaw and 6X30 edge sander. Does bass fretboards as well, no chipout or chance of chipout ever. Perfectly smooth and perpendicular edge ready for binding, with no chance of accidentally planing the side facet off 90 degrees. Fast, easy, and extra-fine control over where the edge is.
If I WERE to use a handplane, I'd go sideways on a shooting board as if I were jointing a top.
Old growth, shmold growth!
PostPosted: Thu Dec 16, 2010 9:59 pm
Sure. I copied it from several others. The sled rides on the slot to the left of the blade.
PostPosted: Thu Dec 16, 2010 10:09 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
very cool jig. I like the simplicity. I used one of those cheap aluminum ones and if I recall correctly made a bad cut which forced me to improvise with edge binding. I think one like yours would work better.
PostPosted: Fri Dec 17, 2010 2:00 am
First name: shad
Last Name: peters
i like the router method, do the work once to make a template and then you dont have to worry about it again.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Fri Dec 17, 2010 5:10 pm
My table saw jig is even more simple. It is about 10"X36"X3/4" (36" because I want to build an accoustic bass one day) plywood sheet with 2 staco clamps. The taper is layed out on the fretboard and lined up with the edge of the sled. The clamps are thrown, the rip fence set to 10" for the first pass. Clamps are released, the other side lined up on the sled edge for the second pass. The edges are (provided you used a good blade) ready for binding, or to be glue to the neck, or fretted, depending on your methods.
Danny R. Little
PostPosted: Fri Dec 17, 2010 8:30 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I don't have a standard taper. I measure the amount hanging over the edge for the taper, and set the fence for the width.
PostPosted: Fri Dec 17, 2010 10:01 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Ditto. I make templates from clear acrylic on my laser engraver, then route the slotted fingerboards using a 1/2" pattern bit in my router table. If you are getting chip-outs, then you're probably using too small a pattern bit (1/4" maybe?) and/or you aren't running the router rotational speed fast enough. I set mine to max (30,000 rpm). Smooth as butta with absolutely no chip-outs! Watch yer fingers though!! duh
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Sat Dec 18, 2010 5:58 am
A dozen or so beers, a squint, and a good hard whack with a broad axe for me...Haven't actually cut a good one yet but the tonewood vendors all reckon I'm a great bloke.. [:Y:]
OK... bandsaw close, and then finish with a hand plane. If the wood is looking nasty just shy of the line the job gets finished against the table saw fence with a sanding board clamped to the table.
PostPosted: Sat Dec 18, 2010 11:40 am
Online
When you get your tablesaw go to Sylvan Well's website and read his tutorial. Simple, accurate, and guarantees symmetry.
PostPosted: Sat Dec 18, 2010 11:55 am
I like the router method, do the work once to make a template and then you don"t have to worry about it again.
That would be a lot of templates.
6 scale lengths, with and with out binding, 2 1/8, 2 1/4, 2 3/8 spacing at bridge and 1 11/16, 1 3/4, 1 13/16, 1 7/8 at nut.
It takes me about 5 minutes to lay out and cut each board.
The router also makes a lot more mess and noise.
YMMV
PostPosted: Sun Dec 19, 2010 10:38 am
Bandsaw to get close then to the granite plate held against a fence for me. Fast and effective.
PostPosted: Sun Dec 19, 2010 11:12 pm
First name: mike
Last Name: heytman
Country: australia
NICE Jig!!!
Can I ask what blade your using and what using on the bottom of the sled to make it track?
Users browsing this forum: Terence Kennedy and 17 guests
