It is currently Thu Aug 21, 2025 6:43 am
PostPosted: Sun Nov 21, 2010 9:24 pm
City: Tucson
State: AZ
I'm contemplating my next build and I like the idea of Bloodwood binding on a Walnut/Englemann Spruce instrument. I'm a bit concerned about the color "bleeding" (pardon the necessary pun ;) ) from the binding into the various woods. I hope to finish the whole thing in tinted danish oil, and it will be hand rubbed.
PostPosted: Sun Nov 21, 2010 11:03 pm
I've used bloodwood several times and never had any bleed problem. I haven't used it with walnut, but it is my favorite on koa or tasmanian blackwood or curly white oak.
On walnut I like curly maple.
PostPosted: Sun Nov 21, 2010 11:25 pm
I bound a spalted maple fretboard with bloodwood, no bleeding.
Padauk bleeds, bloodwood doesn;t seem to in my experience.
Old growth, shmold growth!
PostPosted: Sun Nov 21, 2010 11:26 pm
City: Jacksonville
Ian - IF your finish is going to be Danish Oil then you won't need to seal the bloodwood. Not enough solvent in that stuff to cause the bleeding you speak of. BUT - do a test anyway. White cloth dabbed in some Danish Oil...rub it on a strip of bloodwood and see how red the white cloth gets...apply it the same way you would apply to any other piece of furniture or otherwise...but don't try and MAKE it bleed. BTW I think Waterlox sealer and finish would be a better choice but that's just me thinking out loud.
Chris
PostPosted: Mon Nov 22, 2010 3:22 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I've never had bleeding with bloodwood. Only recomendation is bending the bloodwood binding on high heat,,with little water..I bend on a pipe..Get it good and hot..some pieces depending on how its cut or something just snap easily.
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Nov 22, 2010 7:24 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
If you have runont, it will break. If you have nice Q-sawn pieces, wihtout runout, then it will bend easily, with lot of heat and a bit of water.
+1 with shellac sealing before anything. Checkout your glueing too. If you glue with CA, you'll have more bleeding issues than with PVA or Hide glue.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Mon Nov 22, 2010 7:36 am
Never had any bleediing issues with bloodwood either, bending has been straightforward too, nothing fancy or different, bent easy for me on numerous occasions.
Gwaltney Guitars
PostPosted: Mon Nov 22, 2010 9:48 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Love the stuff. Bent easily for me and looks great. No bleeding with me.....not that a band aid wouldn't take care of.
kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Mon Nov 22, 2010 10:15 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I recently bought a nice piece of bloodwood from the local hardwood store'
ripped it into bindings, broke off a piece, and found pretty major runout.
I broke the first try, then made 8 more pieces succesfully, for 2 projects,
1 with serious tight bends.
I used a terry towel soaked with water over a hot pipe.
Steamy affair! It turned to rubber.
I'll let ya know if it bleeds.
Gonna be a while though.
PostPosted: Mon Nov 22, 2010 10:23 am
City: Tucson
State: AZ
Looks like I'll be okay then. Thanks guys bliss
PostPosted: Mon Nov 22, 2010 11:45 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I've had bleeding problems with Bloodwood. Bled when I wiped on a coat of shellac, of all things. It was totally unexpected and stained the curly maple purfling next to it a light pink in the flame. Took a bit of sanding to remove [headinwall] . If you do initial light sealing sprays or seal the lighter woods first with shellac and then come back and seal the Bloodwood you should be OK. You could also surround it something that will not stain as easily as maple.
Tim
