It is currently Wed Aug 20, 2025 10:57 pm
PostPosted: Wed Oct 27, 2010 1:10 pm
I keep breaking these things and it's driving me nuts. My first guitar didn't give nearly this much trouble and it was a tighter bend on an iron with off quarter maple. These I'm doing on my newly finished fox-style bender with heating blanket. Here's my method. I spritz the sides with water then make the sandwich (top to bottom) : slat, blanket, foil, side (.080), foil, slat. I wait till the temp is 280 F then crank the waist down till about 1/2" from the form then do the lower bout then do the cutaway then go back and do the rest of the waist moving pretty briskly as per John Hall's youtube video. Even though I'm new to the bending machine I still get this all done in under 5-6 minutes. The last set I let sit in the machine over night and this is what I keep ending up with. Any thoughts, suggestions?
Jason
PostPosted: Wed Oct 27, 2010 1:19 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I'd say its too thick and too fast. What's the hurry to get it bent in 5 minutes? Maybe thin the cutaway area down to 0.07". Even bendable wood doesn't bend that fast. Maybe slow down next time and let it relax
PostPosted: Wed Oct 27, 2010 1:30 pm
First name: jack
I bend maple dry / no spritz of water
PostPosted: Wed Oct 27, 2010 1:37 pm
I would take that to about 75, and it should bend well .. light spritz, not wet ... and I bend fast as well, there is really nothing to wait for once the wood hits temp - but it must be supported, and even under some tension when bending ... my slats in the upper bout are both spring loaded (inner and outer) for venetian bends, as the first bend is outside, the second inside.
we bent exactly that shape last night in EI rw, heat for 2 minutes, bent in 3 .. beautiful.
PostPosted: Wed Oct 27, 2010 1:53 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
I've bent numerous curly maple cutaway sides. For the cutaway, sand that area to .0625 to .070. I spritz with filtered water. I have tried super soft on maple and find that it leaves permanent stains. For me, I spend about 5 minutes total to bend one side for flamedd maple. Just a little turn at a time - and hold your breath!
John Ressler
PostPosted: Wed Oct 27, 2010 2:10 pm
Thanks guys. I'll try pulling up a bit more on the cutaway end while I crank the ram down. I'll see if that doesn't put a bit more tension on the back side.
Jason
PostPosted: Wed Oct 27, 2010 2:17 pm
Further to what Tony said regarding support: I would recommend putting the blanket on top of the slat, i.e. so that the slat is closer to the wood instead of the blanket as compared to your arrangement. I also am a believer in using spring steel as opposed to stainless steel just for the additional support.
PostPosted: Wed Oct 27, 2010 4:02 pm
As Pat just said. Your blanket is in the wrong place in the stack. I always keep a slat on both sides of the wood for support then the blanket.
PostPosted: Wed Oct 27, 2010 4:04 pm
I think you can try the thinnig. Maple does like heat so try it about 350. Once bent lower the temp to 250 and let cool
PostPosted: Fri Oct 29, 2010 3:17 pm
Still no luck. The last set I just broke was .065. I'm at a loss. The last few attempts were with the thinner sides at a higher temp with the blanket on top. Anyone want to come over and show a fella how to do this?
PostPosted: Fri Oct 29, 2010 3:49 pm
call me
PostPosted: Fri Oct 29, 2010 8:10 pm
First name: Nelson
Last Name: Palen
Those outer fibers must be supported by a very tight slat on the outside of the bend.
Some flamed maple will bend just fine and the next set will not.
What is the inside radius on your caul and the mold, Jason, it looks fairly tight.
Nelson
PostPosted: Fri Oct 29, 2010 10:12 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Have you got a portable steamer?
Steam the area after you have preheated and then try bending. It should make the fiber relax and bend like butter.
Kevin Waldron
PostPosted: Sun Oct 31, 2010 2:45 pm
Thank you all for your help. I would like to thank John Hall especially for talking me (down off the ledge) through some of my mistakes. Nelson the radius of my cutaway is about 2" or so. I did finally get some sides to cooperate and now there is once again peace in my shop. Thanks again. You guys/gals are all aces.
Jason
PostPosted: Sun Oct 31, 2010 4:36 pm
Glad to help ,that is what we like to do.
PostPosted: Mon Nov 01, 2010 11:36 am
First name: Tim
Last Name: Allen
City: San Francisco
Jason, I'm glad you got your problem solved. This thread has a lot of tips, but you don't mention how you solved the problem. It sounds like there was some key info in a phone call between you and John. For the rest of us who followed the thread with interest, would you and/or John let us know what seemed to make the difference?
Tim Allen
"Never hurry, never rest."
PostPosted: Mon Nov 01, 2010 11:48 am
First name: Nelson
Last Name: Palen
What Tim said.
Jason, do you mean 2" radius or 2" diameter of the cutaway?
Looks more like a 2" diameter or 1" radius.
Nelson
PostPosted: Mon Nov 01, 2010 9:06 pm
Sorry about that. I was basically letting the wood case harden. I was waiting too long to start bending and letting all the moisture cook off before I got the wood fully bent. John told me to start bending sooner and to take a wet paper towel or craft paper and wrap the cutaway area to make sure that area had moisture. So far so good. I've managed to successfully bend a couple of cutaway sides without anything but happiness. Yes, 2" diameter. Oh, and another thing I've done was to just take a cabinet scraper to the cutaway and bring it down into the neighborhood of .065-.070. Nelson, I'm curious how you go about it since I doubt you're a stranger to bending maple.
Jason
PostPosted: Mon Nov 01, 2010 9:28 pm
First name: Nelson
Last Name: Palen
Jason, glad to hear of your success. I think John is spot on in and I agree that the timing of the bend process is really important.
I used a Fox bender for several years prior to acquiring the Better Way Bender prototype from Brad Way several months back.
It uses the air cylinder tensioned band method of maintaining heavy band pressure against the outside of the bend.
Best regards
Nelson
