It is currently Wed Aug 20, 2025 4:43 pm
 Post subject: non tradional rosete
PostPosted: Thu Oct 21, 2010 5:26 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I am looking for construction & design ideas for contemporary rosettes.
What is the thickest they can be? If using veneers at .025 what can I use underneath the show veneer to reinforce it. I did a furniture pedestal leg recently & glued my veneer on to a 'poly' material similar to the underside of laminate & liked the results. I wonder if this would work but somehow think there may be a wood movement issue?
MM
Mike McNerney
 Post subject: Re: non tradional rosete
PostPosted: Thu Oct 21, 2010 5:31 am
Country: Romania
I woudl use simply more veneer, bought maple or homemade spruce, however it seems to me 025 is too thin for a rosette, you really risk planing/sanding through.
Build log
PostPosted: Thu Oct 21, 2010 7:19 am
Last Name: Kincheloe
The walnut burl and curly maple on this one are .025" veneer. Aside from the difficulties of cutting it, I haven't had any problems in the 6 months since it was assembled. I haven't allowed it to dry out, but it has seen up toward 70% humidity on a few rainy days, with no finish on it. It's all glued down with LMI white glue, no CA. Inlay on headstock is the same maple, also with no problems.
I was very careful not to touch it until final sanding time though, and it has the deeper purfling line borders to fulfill the practical purpose of the rosette of catching any cracks that may form at the soundhole.
Next time I'll probably glue the good veneers to another layer or two of veneer, something plain and cheap, simply to strengthen it for cutting. Maybe alternate grain to make a micro-plywood :)
This one I ended up cutting the maple stuff with a dremel router, as I couldn't avoid breaking it with a jeweler's saw or X-acto knife. Walnut ring was just X-acto knife, first to rough it out, then slicing lots of slivers off of it while checking fit. Probably wouldn't need to bother with a second layer on that, as it was pretty easy. Big, so not too delicate, and didn't have to be perfect since I'd be routing off the edges of it for the purfling lines in the end anyway.
PostPosted: Thu Oct 21, 2010 7:40 am
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
That's gorgeous Dennis!
Bobby Masten
