It is currently Tue Aug 19, 2025 11:02 pm
PostPosted: Mon Aug 09, 2010 7:36 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
I just read something about .085 being way too thin for a cedar top for a dread. Can I use it for a much smaller guitar size. What about a small size 1 or 2 parlor guitar? Should you go thinner on smaller guitars?
What about redwood? How thick for a 00 or 000 size?
PostPosted: Tue Aug 10, 2010 9:32 am
.085" is way too thin for a D, even if it were a very stiff spruce top. Personally I wouldn't use anything that thin, on anything.
I usually leave WRC or redwood 10 to 15% thicker than spruce, and yes smaller guitars allow slightly thinner tops. I select the tops with the least stiffness across the grain for small guitars. But regardless of the guitar size, you should still be concerned by longitudinal stiffness, so the variation is not that great. On a 0 size guitar I may thin the top down to 10% less than on an OM.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Aug 10, 2010 2:39 pm
I built a 00 sized guitar with a Cedar top that was .95 thick. It was a disaster. It bellied so bad within the first 3 months that I had to re-top it. It did, however, sound great for that first couple months :)
For a 15-16" guitar I'd suggest around .125 for cedar/redwood. Perhaps a tiny bit thinner, but that would depend on a host of things.
PostPosted: Wed Aug 11, 2010 2:21 pm
You might get away with it on a small classical or Flamenco, with a low saddle and light strings. Or you could learn about the joys of lattice bracing, and thin it out even more.
PostPosted: Wed Aug 11, 2010 7:05 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`ve done both cedar and redwood.What John said around.125 works out well.
james
James W Bolan
Nashville Tennessee
PostPosted: Wed Aug 11, 2010 8:08 pm
First name: Dan
City: Brooklyn Park
State: MN
Ladder bracing!! Could I use my very thin cedar top on a very small parlor if I ladder brace it?
PostPosted: Wed Aug 11, 2010 8:36 pm
Lattice not ladder.... huge difference
PostPosted: Wed Aug 11, 2010 8:57 pm
Last Name: Abercrombie
You can also use lattice bracing without very thin (Smallman style) tops.
Lots of possibilities, though you would have to give some thought to the location of the string holes if using a pin bridge.
Classical 'lattice' by Greg Byers
Sergei deJonge style lattice could easily be adapted to steel string, I think.
PostPosted: Thu Aug 12, 2010 5:05 am
First name: Dan
City: Brooklyn Park
State: MN
Lattice? Never mind. - (Roseanne Roseannadanna)
PostPosted: Fri Aug 13, 2010 11:04 am
First name: Dan
City: Brooklyn Park
State: MN
John & Laurent
Thanks for the advice on cedar top thickness. Those numbers were just what I was looking for.
I'll save my ,085 top and use it for a very small bodied travel guitar - with a lot of bracing.
Users browsing this forum: DennisK and 23 guests
