It is currently Tue Aug 19, 2025 11:04 pm
PostPosted: Wed Aug 04, 2010 9:54 am
Well, I trashed the top on #5 last night, trying to fix a little problem... gaah Multiple reasons, but in reality, it was my carelessness that caused it. This guitar has been a troublesome stack of errors and negligence! Anyway, some purfling lines, somehow, popped out when I was leveling them. It was pretty thin, and certainly may have been a bad glue job. In trying to repair that, I let my purfling cutter (the one I made) slip, and carved a nice cut across about 3" of the lower bout near the tail (very visible place). I was going to try to fix that, but realized that that cut would show, no matter what I did. Decided to add another purfling pair around the perimeter. It was really getting wider than I wanted, but I started by cutting a groove around the inside of the already wide purfling. Well, there is a degree of unevenness that limits my capabilities, and in removing sections, popped some Spruce. The whole thing was going to look like a mess, even if I got it done. Decided that replacing the top may be about as easy. Or, maybe not. I'm hoping i can salvage the rosette, and the TB's. If I can get the top off the TB's it would make re-topping a lot easier. I'll have to be careful removing though. Any Suggestions?
This was where it started. Looked minor. Tried to patch in a piece. Looked terrible. Decided to replace from the break point to the tail, and that's when things got out of hand. All my fault for not using a wrench to tighten my purfling cutter. It slipped when I was trying to slit along the purfling to keep it from chipping. Live and learn! [headinwall]
PostPosted: Wed Aug 04, 2010 10:06 am
Waddy,
Here are a couple of tutuorials you might find useful.
http://www.grevenguitars.com/GrevenGuitars.html
http://www.guitar-repair.com/article_apr_09_retop.htm
Jimmy Caldwell
Two words: inlaid ornament :D
I had a router slipup when routing the back binding channels on my first so I did this. Non-luthier friends say "cool man". Luthiers say, "cool coverup man, whadga screw up?"
You can put a corresponding inlay on the opposite side in the upper bout to make it look intentional.
PostPosted: Wed Aug 04, 2010 10:20 am
Too late for creative ornamentation. It's much worse now, as I was trying to cut a new purfling groove, and it wasn't going well at all. It's a mess. Re-topping is the only solution. I'll check out those links. I'm familiar with the one where you rout the top out, but, alas, I don't think it's going to work for me. Bending by hand, and such, creates a bit of unevenness that precludes and exact route out of the top. Also, because it's a classical guitar, the top in the lower bout is only about 1.8 mm at the edges, while in the upper bout it's 2.5 at the edges. I guess I could just adjust as I go. Do the lower bout in one pass, then adjust for the upper bout. Might be worth a try. Don't know about the evenness of the thickness of the binding though.
PostPosted: Wed Aug 04, 2010 10:39 am
Been there, done it . . . on more than one occasion. The good news is that it can all be fixed, it just depends if you want to spend the time on all the remedial work. I think I'd be tempted to remove the bindings and redo all the purfling, making sure the ledge is nice and flat and with clean edges. Sandpaper glued to small curved blocks help clean up the ledge. Chip outs in Spruce can be made virtually invisible if you have soundboard off cuts but it really is advisable to practice inlaying patches on off cuts first. In the process you learn some of the skills of the repairer/restorer.
PostPosted: Wed Aug 04, 2010 11:13 am
Thanks, Michael. I figured, it would happen one of these days. Just a matter of time. I have patched a couple of little chips on other guitars without issue, but this thing is beyond patching now. I'm committed to the salvaging of the guitar, though. I may replace the binding and purfling, but I think I'd like to re-top it first then take off the binding and side purflings. That would help keep it together, since my side bindings and purflings are so deep, due to the slipping of my router depth collar,when I was cutting them. If I can get a top in place, it'll reinforce the dentellones when I take off the binding and purfling. I don't know! I'll just have to see when I get there.
PostPosted: Wed Aug 04, 2010 11:15 am
First name: duh
Last Name: Padma
Mac Tack Waddy, mack tack , comes in assorted wood grains and in different colours too.
Peal the back off, slap it down, run some black duck tape around the edge, tuner her up and send on down the line.
blessings
the
Padma
PostPosted: Wed Aug 04, 2010 12:20 pm
First name: David
Last Name: LaPlante
Hi Waddy, Sorry to hear.........Steve Kovacik's article on www.guitar-repair.com shows how you can trim the new top to the precise outline of the inside of the binding or purfling.
This is done with a router and the actual top removal can be done with hand tools.
Seems to me that this would enable you to preserve the glue blocks as they are as well as the geometry of the guitar. I would use the original binding edge to "trap" the top to glue it, then rout out the binding and redo to either match the back or redo both top and back binding/purflings.
The point of this on a restoration is to keep the original binding/purfling intact which can be impossible to match with modern materials.
In this case though since you can replace the bindng etc. the technique provides a way to preserve the most in terms of internal structure and geometry that you've created thus far.
PostPosted: Wed Aug 04, 2010 12:34 pm
Ouch!
Waddy if you've already decided to trash the top you can easily remove it cleanly by routing it off with a rabbet cutter that cuts just a little wider than the width of you sides+linings, set at the depth of cut at the top thickness and go for it. I do this on experimental guitars steel strings though with the neck off. I think you'll have to get creative when dealing with a classical in the fingerboard area, it may need to be removed.
jim
PostPosted: Wed Aug 04, 2010 12:39 pm
Thanks, David. That is exactly what I would like to do. Preserve the innards, that is. I just need to "gut up" and do it! eek Thanks for the link.
Fortunately, Jim, I have not put on the fingerboard yet. Glad I didn't go ahead. I was getting ready to, then I thought, "Waddy, you'd better see what you can do with that repair before gluing more stuff on." One of the few smart things I have done on this one!
PostPosted: Wed Aug 04, 2010 12:46 pm
Oh, no, Filippo! I made it much worse. Cut a 3" stripe about 2mm from the purfling across the tail. Then tried to add more purfling and made a mess when grooving for some additional lines. It ain't pretty! I didn't take a picture, but will before I start removing. That picture was just what started it.
PostPosted: Wed Aug 04, 2010 1:33 pm
I'm learning that fast. I had to re-back #2 when I was doing it. I've trashed a few bridge blanks too. This'll be my first top. Unfortunately, it was a good one. Great tap when braced.
PostPosted: Wed Aug 04, 2010 2:36 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I understand your frustration, Waddy. As I'm sure all of us do. I'm on my second binding install, myself. I almost reduced my current build to a pile of ashes in frustration over the weekend. In retrospect, I am glad I didn't, but I still hold to my guns thinking it would have been very therapeutic.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Wed Aug 04, 2010 3:16 pm
First name: David
Last Name: LaPlante
Some additional thoughts Waddy,
If you keep your present binding for the time being (i.e. flush with the top). You can "drop in" the new one ever so slightly thicker then sand down to the level of the old binding to replicate your present top thicknesses.
Since the guitar is kept intact while the new top is "blocked up" above the old in order to precisely trim it to size and shaped with the router (using the sides of the guitar below as a guide) there is not much risk (beyond the new top blank) in givng this a try. Once the new top is trimmed so that it will "drop in" once the old one is removed, it's just a straightforward process of transferring or (maybe you should think about keeping the old one intact to make a smaller guitar with?) installing the rosette and bracing it up.
PostPosted: Wed Aug 04, 2010 3:39 pm
Thanks, David! Excellent points to keep in mind as I go forward.
PostPosted: Wed Aug 04, 2010 5:32 pm
First name: Jim
Last Name: Kirby
Good luck with it, Waddy. I've had to take a back off myself, after realizing that the neck was set at entirely the wrong angle. Luckily, I've never trashed a top.
Jim Kirby
kirby@udel.edu
PostPosted: Wed Aug 04, 2010 6:30 pm
First name: Jim
Last Name: Kirby
Filippo,
I hear you. I think that's what people refer to as "slipping the heel" and I guess it's the standard way of doing a neck reset on a Spanish heel guitar. I think I was just in eek wow7-eyes [headinwall] gaah mode, and got a little over-active.
Think before you leap!
Jim Kirby
kirby@udel.edu
PostPosted: Thu Aug 05, 2010 10:53 am
NO one to run to around here! Well, no one I know well enough to run to, anyway. There are a couple of other classical builders in the area, but not in convenient locations. However, advice received here has been good in most every case. Can't say I've ever been steered wrong. Sometimes I had to choose my medicine, but none was wrong. It's nice to be able to choose the way you are most comfortable with. I planed and joined a new top (Shane's Lutz - man that's pretty stuff) last night. Shot a good joint with a plane for the first time, without the help of sandpaper! bliss Thanks, Todd, for the instructions at John's place, and for the "door prize" slanted shooting board. Worked great.
PostPosted: Thu Aug 05, 2010 12:54 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Waddy if you put a piece of tape on the f.b. and mark the center line
and do the same at the butt(where the sides meet ) it will
help you allot in lining up a new top.
Mike ;)
Mike Collins
PostPosted: Thu Aug 05, 2010 1:01 pm
Thanks, Mike. Good pointers. This is a 5 piece neck, so center is easy to see, plus I have a notch in the sides at the neck that needs to fit. there.
The tail needs to be centered. I'm hoping I can leave the bindings at full height and drop the top in place, then route the bindings off as David recommended, which leaves me with a top in the right place, as it will have a boarder to force it in place.
PostPosted: Thu Aug 05, 2010 1:34 pm
Last Name: Collins
City: Argyle
State: New York
Waddy ;
is it not the purfling mistake that makes you want to change the top?
Mc
Mike Collins
PostPosted: Thu Aug 05, 2010 1:38 pm
Yes, why?
PostPosted: Thu Aug 05, 2010 1:43 pm
Last Name: Collins
City: Argyle
State: New York
Is the top so dinged up that adding new binding & purfs.
would make it to thin or unstable ?
I must be missing something !
I'll read your posts over again!
Mike Collins
PostPosted: Thu Aug 05, 2010 1:59 pm
Here's the rub, Mike. I already have nearly 5 mm of purfling on a top with 8 mm dentellones. Plus, as I was trying to cut a slot, as I was going to add two more lines, that would account for my screw-up, I did some more damage. I was doing it with a chisel, and I got a bunch of chip out around the edges. Too close a job for the tools I had, I guess. I made a little chisel out of a jigsaw blade, but it's not very efficient. I can't take it any farther or there won't be any support under the purfs. Not sure I want to trust the top to hold up to that. There is some variability in thickness of the bindings, which makes it nearly impossible to get a clean cut with a purfling cutter to make a groove that is even enough to create the purfling channel. Anyway, that's my read of the situation. Believe me, I wasn't planning to re-top this sucker! I was ready to glue on the fingerboard and bridge and string it up.
PostPosted: Thu Aug 05, 2010 2:37 pm
Country: Romania
My extra wide purfling scheme is nearly 5mm too but I use regular 5.5 linings....talk about building on the edge! I plan to switch to 6 maybe 6.5mm linings in the future but anyway you get the idea. As for extra thin chisels, i made a nice one from a 0.5mm sewing needle. Worked wonders for making room for a damaged veneer bit in a rosette.
Anyway if you actually have to retop... [xx(] you have my full sympathy.
Build log
Users browsing this forum: doncaparker and 24 guests
