It is currently Tue Aug 19, 2025 11:18 am
PostPosted: Sun Jul 11, 2010 11:53 pm
First name: Alexander
Last Name: T
Zip/Postal Code: 99025
I'm sure it's been covered before but searches also turn up results for b/w/b, 20/20/20 which is discussed much more and easily done with a 1/16th" bit. Anyone using a .020/.020 around the rosette? I need to find a router bit!
The purling is .04"
Stewmac has a 3/64th" router bit that would be the closest to working.
3/64th = .0.046875"
It seems the extra .0068 wouldn't even be noticable, especially considering the inconsistencies that purfling strips are, and even bits themselves it seems. I'm sure once glue is added and it swells it will be a perfect fit but comments and reassurance would be great! Thanks!!!
PostPosted: Mon Jul 12, 2010 1:01 am
I use micro mill bits like these -
http://cgi.ebay.com/10-Micro-Solid-Carb ... 23085eb38c
http://cgi.ebay.com/Carbide-Micro-2-Flu ... 5d29e9b5d7
PostPosted: Mon Jul 12, 2010 1:19 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I would use a normal 1/32" bit and take two passes at it, moving the bit out by 10 mil for the second pass. This will make a channel about 41mil wide, which will allow easy fitting of the purfling.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Mon Jul 12, 2010 6:41 am
http://bqtool.com/cart/index.php?cPath= ... 54cdddab21
I use the square end mills. They also have a .020 mill that you need to call to order. For rosetting I use a modified circle cutter that uses my die grinders. Todd Stock Made one from Lexan , he should post that picture , it is not that difficult to make and workds very well.
PostPosted: Mon Jul 12, 2010 7:57 am
here ya go...
PostPosted: Mon Jul 12, 2010 3:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Terry Stowell wrote:
here ya go...
I SO got to get one of those air dive pencil routers!!! Been high on my acquisition list for sometime.
PostPosted: Mon Jul 12, 2010 4:25 pm
here ya go...
Me too.
