It is currently Fri Jul 18, 2025 8:50 am
PostPosted: Sat Jul 10, 2010 5:37 pm
I use vortex tools - not cheap but excellent quality and you'll find most center cut.
Vortex Tool
www.morganguitarworks.com
www.morgancustomguitars.com
PostPosted: Sat Jul 10, 2010 7:44 pm
Last Name: Garrish
It's hard to tell, not enough contrast, but it doesn't look like those are end cutting. If it's a real tooling supplier, then you can assume everything solid is end-cutting. You'd be better off with 2-flute cutters for boring holes, there's no advantage to a four flute cutter unless you like the smell of burning wood.
If you only need specific sizes then I'd recommend seeing what you can do at USA Carbide. You'll end up with cutters you'll never need to replace, and their 2-flute grinds are very sharp which makes them work quite well in wood.
Do you mind disclosing the application? There are very few applications that need a truly flat bottomed hole, and drills are a whole lot cheaper than end-mills if money is a concern.
Bob Garrish
PostPosted: Sun Jul 11, 2010 12:22 pm
Last Name: Garrish
I'd suggest grabbing one at the (I assume) size of your magnets along with a 1/8", 1/4", and 1/2" from USA Carbide. The other three will be the best 'router bits' you've ever owned :)
Bob Garrish
PostPosted: Mon Jul 12, 2010 6:59 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Been very happy with these folks and they will do a custom make order with 25 bits (sometimes less, everything is mostly German made) if you have something unusual.
http://www.guhdo.com/
Kevin Waldron
