It is currently Tue Aug 19, 2025 12:22 pm
PostPosted: Wed Jun 30, 2010 9:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I use a lot of fiber board, and I always dread cutting it. I like making my own purfling strips. I know I canby sheets of it from Stew-Mac, LMI, RC Tonewoods (they carry more interesting colors, btw). I have found that once it is laminated, it is even harder to cut (with a razor). There has got to be a better way. I would be happy if vendors would sell a service where it is precut (and, essentially they do, but it causes the per sheet price to rise out of site).
I have looked at those matte board cutters in their various incarnations, none seem to be ideally suited for this task, or they are so freaking expensive...
So, has anyone ever finally skinned this cat in a way that is easy to replicate?
Yes, the Proxon saw crossed my mind as well as wire bandsaw blades (have not found those yet).
Argh!
PostPosted: Wed Jun 30, 2010 10:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, what I have now is to 48" pieces of right angle aluminum, one side is longer than the other. On the outside edge (widest side), I glued 120 grit sandpaper so that when the two come together (with the fiber between them), it looks like a T from the end view. I clamp along the wide edge to hold the piece in place. This little set up cost maybe $20. I leave maybe .12" of fiber above the T and slice it off. Problem is, its still to dang hard to do. So, I just bought one of those 22 TPI Japanese Flush Cut saws. Hope this makes the difference. It cost $19.
Maybe I will try my little Delta bandsaw with that jig Chris Paulick helped me to build
PostPosted: Wed Jun 30, 2010 10:39 pm
Bandsaw, quick and easy. 1/4" blade works just fine.
PostPosted: Wed Jun 30, 2010 10:41 pm
First name: Stuart
Last Name: Gort
How thick is it? I don't know what you are using or how much you use.
Could that be cut on a commercial, guillotine type paper cutter?
Maybe you could get a commercial printer or paper company to cut fiberboard strips for you just before they change the blade on their cutter. Commercial printers regularly change out blades for sharpness. Maybe that's worth a phone call or two.
StuMusic
PostPosted: Thu Jul 01, 2010 12:29 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Really? No issues? I built a wooden zero clearance insert, guess I should try it...
PostPosted: Thu Jul 01, 2010 12:38 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Ok Filippo, I remember this device from other posts. But it's a chicken and egg device, is it not? U still have to get it small enough to fit in the slot, right? Or could it be made with an adjustable side? Plus, a rotating blade would be an improvement, don't u think? It is devious though! ;)
PostPosted: Thu Jul 01, 2010 8:08 am
First name: Coe
Last Name: Franklin
City: Decatur
Filippo,
There is a device that I`ve been meaning to re-aquire that I used for refacing cabinets with veneer about 15 years ago. I can`t for the life of me remember who made it, but it is a tool held in one hand, and the workpiece is fed into it, and drawn accross two very sharp circular cutters.
Totally adjustable up to about 2 1/2" IIRC.
A very handy tool, although expensive. About 125.00 USD back then.
Coe Franklin
PostPosted: Thu Jul 01, 2010 9:27 am
Mike, I use a "slitter" kind of like Filippos viewtopic.php?f=10117&t=19132
I'm sure the concept could be adapted to wider sheets.
Milton, ON
PostPosted: Thu Jul 01, 2010 10:12 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Dave, your concept is pretty slick! Thanks!
PostPosted: Thu Jul 01, 2010 2:51 pm
First name: Rob
Last Name: Thompson
Cocephus wrote:
Filippo,
Coe Franklin
Virutex Laminate Slitter:
They make a bench mount clamp for it too. Works great on veneer and formica, I'm sure it'd be perfect for fiber.
Peace,
Sanaka
...imagine there were no hypothetical situations...
PostPosted: Thu Jul 01, 2010 3:11 pm
Last Name: Abercrombie
That Virutex slitter look like a neat product, but it might need some modification (?) since the manual mentions:
Strip width adjus. from........12 - 110 mm (1/2" - 4½")
One minor problem I've found with slitting fiber with a blade/knife is that the fiber develops a 'furrow' where it is cut, so you have to scrape/sand the strips to get them 'flat' again.
PostPosted: Thu Jul 01, 2010 4:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yeah, 1/2" is obviously too wide, but it would solve part of my "chicken & egg" problem...
However, at $130, I think I will use my bandsaw to solve that problem. ;)
PostPosted: Thu Jul 01, 2010 6:26 pm
First name: Rob
Last Name: Thompson
I'd think some kind of auxilliary fence to slip in there would be easy enough to yield a smaller rip. It leaves a nice clean sheared edge whereas I'd think a badsawn edge would be a little fuzzy. But yeah, $130 buys a lot of extra fiber :)
Peace,
Sanaka
PostPosted: Fri Jul 02, 2010 5:17 pm
First name: Rob
Last Name: Thompson
Just another thought: I wonder if a scallop tooth bandsaw blade would work. They're like a serrated knife and designed for cutting foam and soft materials. Seems like it would handle something thin like fiber sheet and would make a slicing cut rather than a chip forming cut, perhaps leaving a nice clean edge.
Peace,
Sanaka
Users browsing this forum: J De Rocher and 20 guests
