It is currently Fri Sep 19, 2025 3:30 pm
 Post subject: Building amplifier
PostPosted: Sun Mar 28, 2010 4:58 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hi!
After I just finished my first electric bass, I'm planning to build a Tube amp.
Do you guys know where I could get plans, schematics, or either kits, supplies, etc?
Thanks!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: Building amplifier
PostPosted: Sun Mar 28, 2010 6:30 pm
Last Name: Abercrombie
Ti-Roux wrote:
Hi!
Thanks!
Francis
Francis-
I've built a few tube amps 'from scratch' and repaired quite a few as well.
I built a clone of an Ampeg B-15N, which is a tube bass amp (great for guitar as well).
There is a LOT of info on the internet on building guitar tube amps- most of them could be easily adapted for bass, or you could just get a bass amp schematic and build a clone.
What sort of amp are you thinking about? (power level- for playing at home, gigging, etc?)
You probably know that most bass players prefer solid-state amps- it's a lot easier/cheaper to get the high-power levels needed for bass, and there's not much need for the 'tube distortion' sound for bass, usually..
I don't know of anybody producing tube bass amp kits - there are lots of Bassman kits around, but they're usually used by guitar players, I think. (Google 'Bassman amp kit'...)
Lots of schematics at http://www.schematicheaven.com/
Also, it is not particularly cheap to build a tube amp if you use new, good-quality components - something to keep in mind.
(The 'cheap' route is to re-use transformers from old hi-fi or PA amps)
Let me know if I can help with more info.
