It is currently Sun Aug 17, 2025 2:46 am
PostPosted: Sun Mar 21, 2010 12:31 pm
There have been a couple of great articles on making an electronic control unit for a side bending jig and I just can't find them in the archives. Any help directing me to those would be GREATLY appreciated.
I am working on some improvements in my current tooling and this is one of them. Thanks in advance.
-j.
-jack handy
PostPosted: Sun Mar 21, 2010 1:33 pm
Hi J.
Here are a few:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=26461
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=19892
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=25297
Rick
PostPosted: Sun Mar 21, 2010 3:09 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have done this and if you have any questions feel free to PM me, the threads mentioned above will give you enough info to get started. I am a retired controls electrician from an auto plant paint shop and spent many hours maintaining and programming PID temperature controllers.
Fred
Fred Tellier
PostPosted: Sun Mar 21, 2010 3:59 pm
Last Name: Abercrombie
Fred-
Do you have any info on sourcing a practical-shape and size thermocouple for a bending setup? Most of the ones I've found online seem to be 1/4-20 or bigger. Something nice and flat to tuck under the blanket/wood would be just the thing.
PostPosted: Sun Mar 21, 2010 4:20 pm
First name: Fred
Last Name: Tellier
City: Windsor
I use a piece of type K thermocouple wire stripped and twisted together at the end, it fits between the blanket and slat better than the one that came with my controller and is a little quicker to respond as there is less metal to heat and cool.
Fred
Fred Tellier
PostPosted: Sun Mar 21, 2010 7:50 pm
Fred
Fred-
What's the easiest source for that wire? Buy another type K thermocouple and 'hack' it?
PostPosted: Sun Mar 21, 2010 8:17 pm
First name: Fred
Last Name: Tellier
City: Windsor
I just cut my TC wire in half and now have 2 the wire was plenty long. I wish I had been doing this when I was still working we had both type J and K wire in huge rolls, as it has to go from the location of a thermocouple back to the controller sometimes very long runs.
If you are interested in how they work read this.
http://www.capgo.com/Resources/Temperature/Thermocouple/Thermocouple.html
These leaf style thermocouples might be real good for our use in bending blankets.
http://www.microdaq.com/thermocouples/leaf.php
Fred
Fred Tellier
PostPosted: Sun Mar 21, 2010 9:22 pm
Thanks, Fred.
PostPosted: Mon Mar 22, 2010 8:09 am
First name: Fred
Last Name: Tellier
City: Windsor
I came across this simple and cheap thermocouple http://www.auberins.com/index.php?main_page=product_info&products_id=144 it will fit in the blanket slats wood stack real well and is a little stronger than a twisted wire TC.
Fred
Fred Tellier
PostPosted: Mon Mar 22, 2010 10:08 am
First name: Nelson
Last Name: Palen
Fred--Would you happen to know of a source for a switchable input box for inputting different probes into a single input PID controller?
Maybe this is not possible but would like to use probes at two or three different locations on the side being bent.
For example, the first probe input would be used for bending the lower bout, the second for the waist and third for the upper bout and/or cutaway.
This scenario would involve short heat blankets for the area being bent.
Nelson
PostPosted: Mon Mar 22, 2010 11:22 am
First name: Christopher
Last Name: Otto
City: Brown Deer
State: WI
Zip/Postal Code: 53223-2920
Nelson
Google shows a few sources -- http://www.google.com/products?hl=en&as_epq=&as_oq=&as_eq=&num=100&lr=&as_filetype=&as_sitesearch=&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=off&q=thermocouple+switch&um=1&ie=UTF-8&ei=JZinS9ChGo_YNdis1YUD&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCAQrQQwAA
But in my opinion, thermocouple plugs/jacks (appropriate to your type of TC & TC extension wire) might be a better solution. Much lower cost, takes up less space. Unplugging/plugging something else isn't that much of a pain unless you're doing it dozens of times an hour or if the plug's inaccessible. YMMV.
PostPosted: Mon Mar 22, 2010 11:38 am
First name: Fred
Last Name: Tellier
City: Windsor
The issue with switching Thermocouples to a single input is the fact that the metal alloy of each wire must match all the way to the input terminal, so any switches would be very expensive and dedicated to one type of couple. one way to do this is to put a dedicated connector on each couple and a single matching connector on the input of the controller, again matching the polarities all the way to the controller. I have moved my digital thermometer around to different locations and the readings don't vary much.
I suggest reading the article at the link I posted above to get a little background info on thermocouples. They are very simple but must be used right, we used to have issues at work when careless coworkers would change out a couple with the wrong type causing huge inaccuracies or switching the polarity of the leads. I spent many unhappy hours sweating on top of the paint ovens repairing these type of mistakes, which we wouldn't see until the oven was hot.
Fred
Fred Tellier
PostPosted: Mon Mar 22, 2010 4:41 pm
First name: Nelson
Last Name: Palen
Fred and Christopher
Using either of the two methods mentioned above, what type of receptacle is available to adapt to the screw type connectors on the PID?
Now I'm using a miniature K type plug by twisting each of the two prongs 90 degrees and inserting into these connectors on the PID.
(Jury rigged, I know)
Thanks for all your help, guys!
Nelson
Edit: Do these jacks/receptacles require the same type couple wire even if it's just a couple inches length?
http://www.davis.com/catalog/product_view.asp?sku=0887876
http://www.davis.com/catalog/product_view.asp?sku=9384053
PostPosted: Mon Mar 22, 2010 5:45 pm
First name: Fred
Last Name: Tellier
City: Windsor
You can cut off the connector and screw the wires directly to the terminals or take the pins out of the plastic casing to screw to the terminals. Once you get to the terminals as long as the wires are not reversed either way will work fine. I cut my connector off as I made 2 thermocouples out of one as it had a way longer cable than I needed.
Fred
Fred Tellier
PostPosted: Tue Mar 23, 2010 4:37 pm
First name: Nelson
Last Name: Palen
Fred, what I'm wondering is if the special couple wire is required to connect this receptable to the PID even if they're located next to each other in a panel?
Nelson
PostPosted: Tue Mar 23, 2010 5:07 pm
First name: Fred
Last Name: Tellier
City: Windsor
The thermocouple wire of the type of the couple is normally connected all the way to the controller so I would do that, though if it is really close you might get away with it. I would try it if you want and compare the results to a digital thermometer up to the range of the heat needed to bend. A few degrees difference should not be a huge issue while bending as we can adjust our set point with the error in mind.
Fred
Fred Tellier
