It is currently Sat Aug 16, 2025 6:30 pm
 Post subject: 13-fret bridge placement
PostPosted: Sat Feb 20, 2010 5:20 pm
I apologize in advance for asking this [i]right[i] after a post on 13-fret guitars, but I can't find that post anywhere (was it in another thread?):
So, I'm about to sketch out the bracing for the top of a 13-fret-to-body guitar. My sense is that if you bump the bridge plate and bracing pattern back the equivalent of the distance between the 13th and 14th fret (on whatever scale length you're using), then you're good to go (b/c that's how far you're shifting the neck assembly back). Is this correct?
And I suppose that the soundhole would have to go back the same distance as well, if you want to keep the same number of total frets?
In the hope that others may benefit as well from any info shared... Thanx!
Ken Mitchell
Durham, NC
PostPosted: Sat Feb 20, 2010 6:34 pm
Hey Ken I'm doing a 13-fret as well. Here is the link to the discussion you were referring to: http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=25935&hilit=13+fret
Just be aware that I am changing scales and shortening the neck.
PostPosted: Sun Feb 21, 2010 7:47 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
To (help) keep me from making mistakes measuring I make my fingerboard first. I'll use the actual fingerboard to locate the soundhole, bridge, and the bracing. This is a 12 fret 24.625 scale, but my process is the same for any scale, or fret/body join.
PostPosted: Sun Feb 21, 2010 11:15 am
the answer is YES.... if you simply slip everything back (including the ammount for the saddle comp and bridge placemetn) by the 13/14 fret distance, its all good - been doing that for years ...
PostPosted: Sun Feb 21, 2010 5:03 pm
Thanks, guys!
Ive thought through this and measured it all out several different ways in the meantime, and came up with the same answer each time, so I was feeling pretty sure about it. I found another post which mentioned subtracting the distance from nut to 13th fret from the total scale length (including compensation). It's all making sense.
Woody, I don't have the fretboard for this actual guitar made yet, but I have the Stew-Mac template, and I have another 25.4 fretboard sitting around, both of which I can use for placing the soundhole, as you mentioned.
I love trying new stuff! bliss
Ken Mitchell
Durham, NC
Users browsing this forum: Michaeldc and 8 guests
